rpd240 »
https://forums.nicoclub.com/rpd240-u36851.html
Sun Apr 01, 2007 10:51 am
Okay, I tried searching and came up with some answers but now I'm stuck. I have a 1991 240sx that I got for cheap that is bone stock. The car has 145k and was in running condition back in November. The car sat in a tow yard until a few weeks ago but it has some issues.
The clutch pedal goes all the way to the floor and although the car will start, I'm unable to get it into gear. I checked for leaks in the clutch lines and found none, replaced the master and slave cylinders and checked the clutch pedal. I bled the lines and found that isn't the problem. It seems the withdrawal lever is not putting pressure on the slave cylinder to keep the pedal up.
Now I realize that it will involve dropping the transmission, but what would cause the lever to suddenly stop pressing on the cylinder? I looked through the FSM but was wondering if anyone experienced a similar problem. Thanks.
