240sx: changing transmission fluid / oil on s13
Articles, modifications, maintenance, DIY's, how-to's and general information for 240sx owners.
sanioll
Car: Nissan 240SX SE
Toyota Camry
finished result.
Follow reverse order to put it back together.
make sure to put plastic rings or rubber bands on top and bottom part of new Lower Rubber Boot. I simply used rubber bands. put them on tight. you dont want your vehicle to smell like a gear oil inside.
Modified by sanioll at 5:13 AM 1/11/2005
sanioll
Toyota Camry
I'm guessing this DIY doesn't belong to 240sx--general chat forum.
how to move it to appropriate section?
EDIT: FINAL UPDATE; AFTER 8 MONTHS OF USE, NO PROBLEMS AT ALL. SHIFTING IS NORMAL IN ALL WEATHER CONDITIONS, AND NO GEAR OIL ODOURS WHATSOEVER.
Modified by sanioll at 3:51 AM 8/22/2005
TravisD
I found that a 17mm wrench and hammer worked well for the fill plug.
ricebike
2002 Quest
2005 Altima
nice tip, Travis that open end wrench or a big pipe wrench would make quick work on the fill plug...
mods; where are the pix???
andox
Car: 240sx
where did all the pictures go?
TravisD
17mm box-end. Won't slip as easy.
ricebike
2002 Quest
2005 Altima
werd: a 12-point box end wrench... i had a 6 point only sooo.... <shrugs>
TravisD
I thought "box end" meant the full circle, and "open end" would mean the "c" shaped type that only grips on two sides (which might be more prone to slipping and messing up the bolt head if the thing's on really tight). I'm not trying to nitpick or anything, just wondering if my terminology is correct.
ricebike
2002 Quest
2005 Altima
terminology is correct...
but a 12 point box end = a closed square shape that would bite into all 4 sides... get it? (nah, u needed a bigger size box wrench to fit over the square end, which i didn't have... grr )
soo, i had one of these in my dad's toolbox:
i took the largest one, said a few expletives then, took the remnants of a floor lamp: the hollow sectioned pipe to use as a cheater bar on this tool... it werx!!!
as for teh drain plug, i used a torque wrench borrowed from autozone (hehe ) & it came off quickly...
so now, my car has fresh redline GL4 goodness!~
Modified by ricebike at 9:40 PM 9/8/2006
AnotherOne-via
a 3/4in. box wrench also works on the fill plug, if you have it laying around and don't have a 17mm.
Modified by AnotherOne-via at 12:54 PM 9/20/2006
2slow2go
Car: 240sx
anyone got pics of where the drain plug and fill plug is? so you open teh drain plug and drain all the oil from the transmission and fill it up and itll use about 2.5 quarts right?
sxxy1992
Car: 1992 Nissan SX SE Convertible
Sannioll, are you using some medium for pictures that some of us aren't privvy to?? I see no pictures at all of parts, pieces, etc. Don't think you mentioned a filter, either, did you??
ricebike
2002 Quest
2005 Altima
sxxy, this applies to manual transmissions only
mod betta change the title to reflect this??? also applies to s14s as well since they're basically the same trans (w/ the latter having an extra sensor)
& what up w/ da pix?
2slow, i am gonna flame u a little bit... nah, drain plug on the bottom/just look for a square recessed plug! fill plug is a square extended plug to the driver side of the trans da OP's thread again!
Modified by ricebike at 2:16 PM 11/15/2006
Bump - Needs editing...
sanioll
Toyota Camry
sorry mates, I do not have those pictures anymore. For some reason they were deleted from the thread. see my signature for DIY stuff. Out of all, I think only one thread still contains the pictures. Makes me wonder why in the world i wasted my time taking those pictures with my oily hands, and then editing them. ehh.
Hey S -
Were they hosted somewhere or were they attachments?
jt15833
Car: 95' 240SX
sorry to bring this one back but when I wanted to reinstall my shifter I had 2 snap rings, one without holes at the end for use with the snap ring pliers. Had no idea wtf to do with this guy so I bought an ISIS short shifter and I like it. But does anyone know if there are even 2 snap rings above the shifter or just the 1?
thanks
Return to “240sx Articles”
