musicsurfman wrote:tube your frame, just have a frame shop direct connect your front and rear frames and add in cross links.
93RPS13 wrote:RB30DETT with 300 h.p. now?
what??? i am planing to run stock RB30DETT with no other mods other than intake, exhaust, and ECU(power FC to run it)
93RPS13 wrote:oh ok i understand if you read the 1st post again it said can the s13 handle 500hp, i didnt say that the engine nessecerly had 500hp as i am asking because maybe in sometime in the future i want 500hp or may 700hp, also the reason i want a 4 point roll bar is because no other cages or bars will let you use the back seats
93RPS13 wrote:but way buy a compressor housing to make it look big, i dont see no big *** rice wing or 24" rims
imusicsurfman wrote:TUBING THE FRAME NEEDS TO BE DONE BY SOMEONE WHO IS REALLY GOOD WITH WELDING NEAR FLAWLESSLY, KNOWS METAL STRENGTHENING, AND CAN LOCATE WEAK POINTS. THIS IS WHY I RECOMEND A FRAME OR UNIBODY SHOP. ANYWAY TO TUBE THE CHASSIS YOU FIND WHERE THE FRONT AND REAR FRAMES END AND THE UNIBODY STARTS. CUT OUT THE WHOLE UNIBODY, AND WELD BOX TUBE METAL AT THE STONGEST POINT ON THE FRONT FRAME TO THE STRONGEST POINT ON THE REAR IN PLACE OF THE TWO UNIBODY RAILS. WITH THAT IN PLACE YOU WELD A FLOOR TO REPLACE THE UNIBODY FLOOR. WELD THE BODY SHELL ONTP OF THE FLOOR. REPLACE BODY PANELS. NOW YOU CAN ADD CROSS SUPPORTS TO REDUCE EVEN MORE FLEX, THIS SHOULD BE DONE TO THE WEAK POINTS IN THE FRAME. NOW IF YOU ADD A ROLL CAGE THERE SHOULD BE VERY MINIMAL TO ABSOLUTELY NO FRAME FLEX OR TWIST.
