lanker45 »
https://forums.nicoclub.com/lanker45-u148552.html
Tue Dec 08, 2009 3:40 am
Yea, could do that if the timeing cover was removed. also, there were No marks on the chain.As a retired wrench, have done alot of tricks over the years to make things work. In this case, my gut tells me that either the damper or the cam gear mark was a Monday or friday production part LOL, and could be off several degrees. Long story short, use a degree wheel and check to make sure its correct. This last one I just picked up from ebay 20 bucks had it at my door. Its put out by Summit Race, it has more bolt paterns then all the others I found, any way thanks.
