I didn't get to be the one to blow up the clutch, but as I am getting further and further into the car, I am finding stuff that just makes me want to drink. ha ha.
I've only driven the car up and down the block since I bought it in October. When it would run with the clutch pedal out, it soudned like there was a marble in the flywheel. When you pressed the clutch, the noise went away.
I've replaced everything :Clutch plate, flywheel, transmission casing, sincros, welded up the diff (better for gravel corners) clutch cable, blah blah...
I have kept track of everything I have done to the car including dollar ammounts since I started...
check this link...
http://www.section8rally.com/teds_project_home_page.htm May have had a beer before this one...
