3dKa24 wrote:I know all this, Im just trying to see why 4-1 is so inefficient with the KA
Well first off there are a few reasons.Lets start with the example of the HOT SHOT VS. the DC sports which are both 4-2-1 design headers. Hot shot is primarilly designed for OBD1 KA's that use 240/248 cams STOCK DC Sports is a 4-2-1 designed for OBD1 KA's that use 240/248 cams STOCK Now no matter where your logic has been it still isn't making any sence to me where you get your cam combination from to power output. It's already been proven since there is increased scavaging using the 248 on the exhaust of OBD1 engines.Now the difference in primaries is that the hot shot uses much larger primaries and a 2.5" collector. DC Sports are a tad smaller and uses a 2,1/8" collector. Now beyond any theory it is proven that the DC sports and the HOTSHOTS are the top 2 headers on the market. The HOTSHOTS makes less HP due to it's larger primaries and collector, exhaust flow and pulses actually slow down in the pipe. DC sports uses a ceramic coating, and smaller collector and primaries to increase exhaust flow, by also keeping the exhaust temprature high and as you can see from the chart it has a pretty substantial torque and HP increase.So for the top 2 headers on the market DC makes relatively 8~9 HP and HOTSHOTS makes about 6~7 HP, a bit more torque than DC.
Now on any reasoning when there have been the Greddy or Megan Racing headers they simply don't make power. On average it's about 3 HP in the top end and that is about it. Shure the headers could make more power if the KA even had a strong enough power band that would ride longer to even 6500.
Considering that 3000RPM to 6000RPM is the midrange power band that is all the KA uses and is why a 4-2-1 works better and is better no matter what cam assortment you claim would work to produce better numbers. It's been proven on OBD1's....
