2024 Versa S Manual Wiring Diagram
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
tali
Car: 2004 Nissan Versa S manual trim
If possible. I would like it also.
[email protected]
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Done, check your inbox. As with previous posters, it's confidential and for personal use only. DO NOT SHARE IT.
Dooklet
Car: 24 Nissan Versa
Anyway I could get the wiring diagram also, trying to install a simple keyless entry in daughter's 24 versa. Thanks
Telkood@ gmail.com
Jon
VStar650CL
Technical Expert
cwoody
Car: 2024 Nissan Versa
2006 Nissan Maxima
I too am looking for the wiring diagrams for the 2024 Versa S to get a keyless entry system installed. Thanks in advance!
--Chris ([email protected])
VStar650CL
Technical Expert
fj_sanabria
Car: 2022 Nissan Versa
Hi VStar650CL,
I would like to install remote start in versa 2022 advance mt, could you share that copy of this version of versa or otherwise could help me to send of copy of version share with the community
Email: [email protected]
Thank you!
VStar650CL
Technical Expert
dman007
Car: 2025 Nissan Versa
VStar650CL, could I also get this wiring diagram please. Looking to install Keyless entry/alarm. 2025 Versa S.
[email protected]
Thanks a ton
VStar650CL
Technical Expert
Leorehin
Car: 2023 Nissan Versa Sense (Brazilian model)
Hello, I have one also and i want to install the SR head unit, do anyone have the bcm wires the stereo?
[email protected]
VStar650CL
Technical Expert
Done, check your inbox. It's for the US model, I can't guarantee it will be identical to your Brazilian version. As with previous posters, it's confidential and for personal use only. DO NOT SHARE IT.
bluebr
Car: 2024 Nissan Versa S
VStar650CL wrote:
Tue Dec 19, 2023 7:45 am
Post your email addy, I'll email you a copy. It will be confidential and for personal use only, DO NOT SHARE IT.
Hi, could you please send to me as well?
[email protected]
VStar650CL
Technical Expert
Lecoeliaque
Would you mind sending it to me too?
[email protected]
Thanks!
VStar650CL
Technical Expert
rtejeiro
alice69 wrote:
Tue Feb 27, 2024 9:12 pm
We were looking for a copy of the diagram for the taillight wiring. We bought a Nissan Versa 2024 and are trying to install our towing gear. We were able to take the taillight apart, but we can't figure out what wire is for what. We have 4 colors (red, gray, green, yellow) on the driver side and 4 colors (red, gray, pink, purple) on the passenger side. Any help would be appreciated. Thank you
Hello there. I am also working on attaching a towing gear, and I was wondering if you figured out how to go about it.
VStar650CL
Technical Expert
VStar650CL wrote:
Wed Feb 28, 2024 6:36 am
You can't go by the wire colors connecting to the bulbs, that's a subharness and can be any wire colors the lamp manufacturer chooses. You need to look at where the subharness connects to the car harness.
For the left side:
Red - Stop
Violet - Park
Pink - Directional
Gray - Ground
For the right side:
Red - Stop
Green - Park
Yellow - Directional
Gray - Ground
Ryez_up
VStar650CL wrote:
Tue Apr 30, 2024 3:55 pm
:dblthumb:
Can you please send the diagram to me as well? I am installing a simple after market keyless entry and I just need the unlock/lock buttons to work. The brand I purchased is a Banvie. I am also having issues removing the bottom dash panel for easier access to the BCM controller. I believe your earlier post shared its pins 53 and 71 but it’s a pain trying to test them in such a tight space. Any guidance would be greatly appreciated.
[email protected]
VStar650CL
Technical Expert
The lower dash isn't complicated, but you do need too pry the end panel off the dash before the lower panel will come loose. Other than that it's just the two screws holding the release lever (10mm hex), then the lower panel pops loose.
Dean96
I need the wiring diagram to be able to hook up a keyless entry and push to start if anybody has one. Thanks in advance
[email protected]
VStar650CL
Technical Expert
JPHILLIPS80
[email protected]
VStar650CL
Technical Expert
JPHILLIPS80 wrote:
Sat Dec 13, 2025 9:54 pm
[email protected]
rafikrafiko
hello please If possible. I would like it also.i have problem whith the mirror turn signal i need the wire diagram thanks
[email protected]
VStar650CL
Technical Expert
AdamAnt
Hi if you don't mind would you please share the dash wiring diagram. I'm trying to install a dash camera in my spouses Versa and it would be helpful. Cheers.
VStar650CL
Technical Expert
I'll need your email to share a PDF, but I strongly recommend finding the Accessory Pre-Wire connector under the driver's dash, then get a standard accessory connector (Nissan p/n T99F6-4RA0A) and use that for hookups. Ground is also on the connector (pin 12, not shown below). That way you can avoid messing with (and risking damage to) the car wiring.
AdamAnt
VStar650CL wrote:
Sun May 31, 2026 1:48 pm
I'll take a look for the pre-wire connector thank you. Email is [email protected]
VStar650CL
Technical Expert
Sent, check your inbox. As with previous posters, it's confidential and for personal use only. DO NOT SHARE IT.
Return to “Versa Technical Discussions”
