This is the wife's Altima, but your Rogue's plug will be in a similar place. You're looking from in front of the driver's front wheel toward the passenger rear wheel.:
Post by VStar650CL » https://forums.nicoclub.com/vstar650cl-u299034.html Wed Aug 28, 2024 1:31 pm
Post by V6er » https://forums.nicoclub.com/v6er-u290953.html Wed Aug 28, 2024 4:14 pm
hm... good to know.VStar650CL wrote: ↑Wed Aug 28, 2024 12:32 pmThey need to be way underfilled before you see any symptoms at all. We saw one Sentra that literally drove around a full quart low for at least 10K (we don't know exactly how long), but it didn't overheat or even get a headache. On the other hand, even a pint high will usually cause a measurable temp increase, and a quart over is usually a CVT death sentence. It's because overfilling causes the fluid to foam, and the foam creates "thin" spots in the fluid film which is supposed to prevent the belt from contacting the pulleys. That creates extra friction which spikes the temperature in a hurry, plus adding extra shear load onto the already-boiling fluid. They don't last long in that condition, we've seen them crap out in as little as 1000 miles.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
