Not sure on the charger, but it keeps up with my wife's iPhone XR while doing carplay. Not fast, but adequate.NMD wrote: ↑Sat Jan 22, 2022 5:56 pmOK, since the thread is titled "2021 Platinum questions", I hope the mods will forgive me for chiming in. Does anyone know what the wattage is for the wireless charger? It's barely keeping up with my iPhone SE (2020) in bluetooth audio mode. I've done this experiment a couple of times, so I think it's pretty consistent. On an hour drive it charges my phone from 20% to about 43%. My previous 2019 SL would rock it all the way to over 90% in the same amount of time via the USB. The phone also gets hot AF. So, my guess would be about 5W, but I'd like to know for sure.
Also noticed the mirrors vibrating, driver side more, passenger side less. Will try to set them as described above. And the mirrors reverse-tilt down one at a time, unlike the 2nd gen., which is a hassle (I back into my garage next to my wife's car), I am at a loss why they would change it like that.
The nav sometimes does this weird thing when it would hiccup and then it shows on on the route but just that, all the guidance is gone save for the arrow pointing straight ahead. You may deviate from the route the map will show it but it won't recalculate. Or, when getting close to the destination and deviating from the route it will give you a recalculated route, but you have to confirm it while it is offered, and if not -- it will try to lead you the most convoluted rout imaginable, like why would I even go that way. It's pretty bizarre, but doesn't happen often.
And a final truly bizarre design decision is no home link, I took it up with the dealer and that opened a whole new can of worms...
But otherwise I love the car, it's such a step ahead even compared to the 2nd gen.
Haven't noticed any issues with our mirrors.
I've had countless issues with the audio/nav system. While I have seen worse from a factory head unit, this one isn't great. Display issues, complete lock ups, weird half locks while in Nav, you name it. One of if not the biggest issue I have with the car.
YES on the Homelink. We thought the same thing. So common I assumed it was standard. Pretty disappointed on that.
Also, the weatherstripping around both front doors leaks slightly. Not enough to actually drip in the cabin on the passenger, but it gets on the A-pillars. If it's just clear rain, not a huge issue. But if you're washing the car and your soap is colored, you get a faint stripe on your A-pillars.
