Happy to help. I'll just need your VIN to make sure I pull up the right documentation. You can PM it if you don't want to post it. I'm actually thinking to do a short "How To" about adding switches to the matrix, since there seems to be a lot of mystery about the subject and they really aren't mysterious. Nissan's documentation about it is really quite good. The ESM's all have a section showing the exact matrix and whether it's arranged P or N, so all you need to do is plot In X by Out Y for the switch you want to use, then get the wire colors from the WD and wire across them with a diode facing in the correct direction. Definitely not rocket science!imtfox wrote: ↑Sun May 02, 2021 10:07 pmAs most that know me will attest: "I'll try anything once"I have several 1N4001 diodes and a few hundred different resistors if I need them. Let me know if you need the VIN or whatever and I'll get it over to you. Thanks for your help, I hope this will be valuable for others too, as I haven't seen a lot of factory integration tips for the latest Sentras.
You're most welcome, and don't apologize. My Dad used to say, "The only stupid question is the one you don't ask and get your a$$ kicked because you didn't." He was right.NissanDriverMD wrote: ↑Thu Feb 17, 2022 6:27 amWow thanks for the quick response! Sorry for all the questions. Just don't want to blow up a new car!
Most of the models till '19 had "saddle" type combination switches that could be replaced without removing the steering wheel and spiral cable, so the kits simply included a new combo switch with a Fog position. The majority of the new stuff is coming through with "full circle" type switches that need a lot of expert disassembly/reassembly. Hence, no factory kits. So you need a separate switch and a diode to utilize the factory mechanisms.NissanDriverMD wrote: ↑Thu Feb 17, 2022 6:27 amIn these Sentra fog light kits, they come with a pushbutton fog light switch that goes into a small slot to the left of the steering wheel. Where I'm confused is, do you know why the upgraded OEM Frontier stalk with fog light control I installed moons ago didn't need an inline diode? Was there one built into the Frontier OEM stalk switch? If that's the case, I'm now wondering if the nissan oem fog light switch for a Sentra SR (which comes with fog lights) might avoid needing the inline diode?
The WD's indicate the Fog system on the '20 and '22 are identical.NissanDriverMD wrote: ↑Thu Feb 17, 2022 6:27 amAlso, I'm assuming the wiring direction you sent on the 2020 Sentra SV should still apply on the 2022 Sentra SV?
