Removing the Mystery From Combination Switches
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
15 Altima Conn M18.png (34.5 KiB) Viewed 2292 times
15 Altima Conn M17.png (29.36 KiB) Viewed 2292 times
15 Altima Combo Sw WD.png (14.44 KiB) Viewed 2292 times
VStar650CL
Technical Expert
PS - It doesn't actually matter which side of your switch the diode is on, only that the cathode on the diode faces in the same direction as the diodes in the Combo Switch.
imtfox
Car: 2020 Nissan Sentra
This is fantastic!!!
My God. I'm totally fangirling over these posts.
Again, homepage-worthy as always.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Nissan wiring schematics are so awful. Color codes and pinouts seem to be made as obscure and cryptic as possible. This post helps a lot.
VStar650CL
Technical Expert
AZhitman wrote:
Mon May 03, 2021 8:50 pm
Glad you liked it!
MinisterofDOOM wrote:
Mon May 03, 2021 8:57 pm
It would have been easier to use the '04 as the example, since the older diagrams have the wire colors and connector silhouettes right on the diagram sheet. However, with the volume of control wiring on the newer stuff (and with Nissan changing harness subcontractors like changing daily diapers), I can understand why they quit doing that. So I figured using the later model would give people a better grasp of how to use the WD's. From your response, I gather it worked. Glad you liked it!
