I'll double-check it next week when I'm back at the shop, but I'm pretty sure the minimum activation speed is 20mph. That's the same as the minimum for most of the "non-parking" driver aids like BSW and LDW. Tailgating won't cause it to function, it's looking at closing speed delta and not distance to an object. Most people don't realize how quickly an ABS can panic-stop a car, so if you actually want to test it, you'll very likely need to pee your pants.smetzger wrote: ↑Fri Dec 17, 2021 8:30 amWhile driving it home I purposely would go and tail gaited my wife's vehicle back on the throughway and then back off trying to see how the AEB warning signals and beeps would work. We were never able to get the thing to beep and were wondering what the issue was or if it only works in a true "accident" situation. I have a parking lot I can use at a business so I went there and put two cones out with 5 ft posts in them and put a tarp over the posts to make a barrier of about 4x5 ft and went at it from 5 mph to about 20 mph and the vehicle never braked automatically or beeped. It DOES NOT have the pedestrian warning device FYI.
So I ask the dealer and he said it only works at 30 or 38 miles per hour ??? which to me seems too fast because if I'm going 20 mph and a person slams on their brakes in front of me for say a kid or a deer and I hit them in the back end it will be a lot of damage and costly issue in this day and age of parts and labor. And to bring it to them they said: "if something is wrong then we will fix it but if nothing is found then it's 168.00 and hr on your dime". So my question is how can I test it to see if it really is not working or is ?. And yes I have checked the dash settings and there are check marks on the brake assist icon and there is nothing on the dashboard. And is there a way to make the "blind spot warning" beeps louder ?. I am assuming that the AEB warning is the same and It is very quiet beeps right now. Thank you, Steve
Hello, I figured I’d give you some time as requested and see what you came up with. Thank you, SteveVStar650CL wrote: ↑Fri Dec 17, 2021 8:39 pmIf I don't post back by Wednesday night next week, freshen up this thread to remind me. Memory is the first thing to go in old age, and the second thing is... umm... hmm... patience, it will come to me....
smetzger wrote: ↑Fri Dec 17, 2021 8:30 amHello. I just bought a 2018 Rogue and had questions about the AEB. I picked it up from the dealer on 12.10.21 as a CPO vehicle. While driving it home I purposely would go and tail gaited my wife's vehicle back on the throughway and then back off trying to see how the AEB warning signals and beeps would work. We were never able to get the thing to beep and were wondering what the issue was or if it only works in a true "accident" situation. I have a parking lot I can use at a business so I went there and put two cones out with 5 ft posts in them and put a tarp over the posts to make a barrier of about 4x5 ft and went at it from 5 mph to about 20 mph and the vehicle never braked automatically or beeped. It DOES NOT have the pedestrian warning device FYI.
Did not know that, I thought cameras were involved but the Gen is 7 years old. I will test the genesis against painted cardboard to represent a car. Foil would be unfair since most cars aren't that reflective. Wil foil test if paint fails.VStar650CL wrote: ↑Tue Jan 04, 2022 8:22 pmDifferent radars respond differently to non-metallic materials. Very good sub-millimeter units can detect cardboard (and pedestrians), but even then the gain is crappy and braking may be late and ineffective. Most of the radars out there today are "traffic" types which won't detect cardboard until they're inches away if they detect it at all. Covering or striping the target with kitchen tinfoil would be a fairer test.
Yah, even a large patch of tinfoil should suffice, say, a foot by two feet. It doesn't take much to generate a radar return, the "chaff" they use to fool radar-guided missiles is basically metallized mylar in strips. I don't know what the minimum operating speed would be for your Gen, since I don't have access to much Hyundai documentation. But it's definitely 3 mph on a Nissan and not 30 mph, that's straight from the Rogue ESM.smetzger wrote: ↑Thu Jan 06, 2022 5:41 amSo to test it I gather I need to do the cardboard in foil and go at it over Say 3, 5 -10 mph ?. And the Nissan tec guy in New Jersey said 30 or more mph ( which as mentioned is a little crazy imho).
Like I need “Myth Busters” to my car ..
I’d be surprised if I’m the first person that has been wanting to test it.
No pedestrian feature for AEB in you’re system? Well throw that out the door for any unfortunate human. You would think it would, I guess it’s no Tesla.
Pedestrians are a tough problem, Casper. Like I explained, no metal. Most of the RAB (Reverse Braking) setups use sonar and not radar for that reason, but reverse speeds are slow and ranges are limited. Even high-powered sonar isn't good past about 50 feet, so for pedestrians in front at higher closing speeds, it's insufficient. That's why the pedestrian feature is a pricey extra, it almost has to be done optically+radar and that means some very sophisticated computer processing and coordination.casperfun wrote: ↑Thu Jan 06, 2022 9:01 amNo pedestrian feature for AEB in you’re system? Well throw that out the door for any unfortunate human. You would think it would, I guess it’s no Tesla.
Not that I came close to running over any in the decades of driving.
A rear collision pedestrian feature is a must since all those stories of families backing up into kids in their driveways.
Curious if your particular system can stop before hitting a kid running between 2 cars or retrieving a ball in front of you.
