2012 rogue center console
marcella
Car: rogue sv
I am looking for some sort of divider for the big rectangular box in the center console. Currently it is a big box that needs to have some sort of insert to organize it better. I have not been able to find anything that is made for this. I tried the dealer, auto supplies but nothing fits. Because of the USB and power plugs in the front of the box is is not just a rectangular box, so it is difficult to find anything that fits. After much searching I finally found 2 plastic popcorn holders at The Dollar Tree that actually do fit, but is not the best solution. Any suggestions?
sprocket
Please see this thread missing-parts-t525016.html#p6001569
philipa_240sx wrote:Qashqai,
The tray in the centre console was deleted starting with the 2010 model year. It is not available in the 2011 model either.
The tray can be purchased, it's not that expensive. Less than $30. The part no you posted is correct: 96925-JM00A
The glovebox divider is part # 68580-JM00A (black) or 68580-JM00B (grey)
marcella
Car: rogue sv
Thanks so much for the quick reply. I did a quick search on Google images and other sites. The pictures (diagrams) for the 96925-JM00A that I saw was for the entire console for about 30. I just want an insert for the box. I tried to contact the companies, but it is Sunday and no one available.
sprocket
I guess I am a bit confused and probably did not answer your question correctly.
96925-JM00A is this part: http://www.flickr.com/photos/21560343@N08/3943349757/
(linking the pic just to make sure we are looking at the same thing)
It effectively divides the console bin in to a lower and an upper space, the upper being the bin insert.
Without this insert, the Rogue's console is a cavernous beast that swallows everything and makes it hard to find anything. With the insert, you can divide your items and access the lower by simply pulling out the upper insert.
Is this what you're looking for, or are you looking for a "tall" divider to split it differently? If you're looking for a "tall" divider, I have no ideas other than your own DIY to fit your needs. Maybe someone else might have a suggestion?
Qashqai
I think the OP is looking for the center console tray. My 2011 Rogue didn't have that part and I found it from a local classifieds.
marcella
Car: rogue sv
You are absolutely right about swallowing everything and making it hard to find anything. I'm sorry to be such a pain, but the picture still looks like a big box.I am assuming that this part is basically a tray that spits the console in half top to bottom with the top part being a tray also? If so that would be better than the bottomless pit. Would you suggest where to purchase this?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Nick2010
Qashqai wrote:I think the OP is looking for the center console tray. My 2011 Rogue didn't have that part and I found it from a local classifieds.
And this fits to 2011 fine? got to have this one, this will help me a lot since, I have to constantly dig everything out every time I need to get something from the center console.
JMed
Car: '08 Nissan Rogue S AWD Pearl White
'15 Nissan Rogue SV Black
I have the glovebox divider on my '08 S model, very useful I would say. But man I need that center console tray... that center console is like a little black hole!
flhtvtwin
Car: 2012 Rogue SV AWD
Did anyone ever figure out if this fits the 2012 Rogue?
I'm going to purchase one if so.
Thanks,
Mark
followingnfront
Car: 2017 Maxima S
If it fits the 11 it should fit the 12 since they are the same
Rogue One
2022 Honda Pilot SE
followingnfront wrote:If it fits the 11 it should fit the 12 since they are the same
I believe you are correct. As far as I can tell, having had an '11 and now a '12, the only significant difference on the interior is the bezel around the stereo is a slightly different size.
sprocket
sprocket wrote:Please see this thread missing-parts-t525016.html#p6001569
Took a pic today, hope this helps 2010+ Rogue owners who may not be familiar with the existence of this insert :laugh:
The Rogue's center console is ~ 9" deep.
The center console tray insert 96925 JM00A divides it in to two tiers, lower ~ 4" and upper ~ 5" and sits flush.
Even with the insert, there is enough room in the lower area (for me) to store a portable GPS with cord and mount, sunglasses, small objects, etc and I find it very handy to keep my center console better organized.
The insert has cutouts on front and back that make it easier to pull it out, it also lets you route cords through. I have a USB extension cable routed through the front cutout so I can easily interface with the USB port without having to remove the insert.
If you don't route the cord through, it may help protect your belongings stashed in the bottom half since a casual glance to a petty thief who's not familiar with the Rogue could make him/her miss the fact that there's actually a divider ;)
Return to “Rogue Forum”
