pedsemdoc »
https://forums.nicoclub.com/pedsemdoc-u162296.html
Sat Dec 30, 2017 11:04 am
A quick perusal of the FSM - you have to remove the dash to get at the heat/AC unit, not a difficult, BUT very tedious job, with tons of screws/clips that you could easily break, not to mention crack your dash as a bonus trying to get at the culprit.
Sounds like it would be a loss at this point, unless you knew a competent mechanic who ought to charge you a whole lot less, and again as Ilya said - that's assuming THAT is the problem...no guarantee.
Sounds like the @$$hole who sold you the beast, blindsided you. Unfortunately it's left a bad Infiniti aftertaste for you - I feel very fortunate, I am on my second Infiniti and I love 'em.
My first, an '06 M45 would've prolly gone to 200k+ miles with only slight cracking of the dash as it's only fault - got rear ended which bent the frame, so total loss.
My 2013 M37 has been flawless as well, except when I caused a short, changing out interior bulbs to LEDs which fried a harness.
The electrical/computerized systems on modern cars are generally the money pit nowadays, unless you're rebuilding an engine or taking it apart, the mechanical stuff is pretty solid (assuming you are doing the scheduled regular maintenance)
sorry about your bad experience, but there are always some lemons out there, regardless of the make and model
