I just got a set of winter wheels/tires with TPMS sensors installed - after swapping out the wheels, my TPMS warning light came on. I have looked through the forums and read about the method to wire the TPMS interface plug to ground and then drive around with the wheels at specific pressures so the system can relearn the new wheels.
However, I have spent several hours over 3 nights looking for this TMPS interface plug, and I have nothing to show for it but some frustration.
I saw in some posts that the interface plug was near the ODB II connector, so I removed the entire panel below the steering wheel and followed all of the wires from the ODB II connector, but no TMPS interface plug around. I cut away some taped up bundles in a few places where it possibly could have been hiding, but no dice. I then read about some cars that have the plug above the fuse box, so I took off the paneling on the side by the fuse box and followed those wire bundles around, but again no TPMS plug could be found.
Most of the posts about this are being done with cars that seem to be older than 2011 - does anyone know if something changed with this model year? Or has anyone with a 2011 been able to locate the right plug?
Thanks so much for your help.
