NJGuy »
https://forums.nicoclub.com/njguy-u191160.html
Fri Apr 18, 2014 1:22 pm
I like options 3 and 5.
Option 3 looks good, since you plan to switch the wheels somewhat frequently. The ATEQ tool appears convenient if this is something you would do somewhat regularly. After a few uses, it'll pay for itself. Also, since all cars going forward will have TPMS, you should be able to use it on cars you'll have in the future.
Option 5 should work as well, as long as you have the time to do it. There is actually a tool that helps out with the grounding process (OTC 3831), but it's up to you if you think it's worth the cost (~$35-$50). A thin wire with both ends stripped can pretty much do the same thing as this tool.
In my '08 EX, I had no trouble finding the connector. I didn't have to remove any of the lower dash trim to access it. However, I did have to move the driver seat all the way back and contort my body a bit for me to get to it. It should be taped to the wiring of the OBDII connector; mine was covered by the electrical tape, so I had to dig it out a little bit. Having one of those headband flashlights would probably come in handy here when you're looking for it.
I couldn't get my EX's TPMS into the diagnostic or learning modes when I tried. However, I only played with it a few minutes and didn't try it with the engine running; I only tried it with the ignition switch in the "ON" position. If I had more time to mess around with it, I think I could have figured it out.
