Shane78ta wrote:Wade And I are both in for drifting
Shane Eichinger
Wade Odrey
Great. You both are on the list.
Shane Eichinger
Wade Odrey
All three of you are now on the list. But could I please get your name? I'm having trouble lifting it from the profile.snowborder714 wrote:Add me to the autox list please.
Also add Eric Loose and Nicole Giarratana to the list for pit entrance. My brother says he's not going to drive my car, but I have a feeling he might change his mind once he sees everyone having a blast!
I've been trying to get to this event for the past few years and my schedule just hasn't worked out, so I'm looking forward to a new autox course!
And if I could be #14, that'd be cool.
You're now registered for both.rossiterian wrote:Im going to be there. if i manage to get the swap done in my 240 ill drift but if i have to take my 350 instead ill most likely just autox so could you please sign me up for both? thanks
Bubba1 wrote: Hi Sky. The track should be better than '07. The corners were deteriorating badly and the drifters did a good job accelerating the deteriorationand spread the debris around. Carlisle blacktop patched the corners several weeks ago. I saw it.
The paddock is unchanged. We're supposed to get 2 pushbrooms. Assuming we have the volunteers, the plan is to sweep any debris during each transition from drift to autocross.
Bubba has the call here, but last year we were using GoPro hero cam's with no issue, i assume as long as its secured, its not a problem!snowborder714 wrote:What is the rule (if any) for camera mounts? I have a heavy duty suction cup mount that I'd like to use.
My camera will be a point and shoot, but a bit bigger than a GoPro (I wish I had one!). I'm definitely going to make sure it's secure, as I don't want to risk my camera flying off.LongBeachCoupe wrote:Bubba has the call here, but last year we were using GoPro hero cam's with no issue, i assume as long as its secured, its not a problem!
We've been pretty liberal with them, especially with growing popularity of go pros. As long as they don't obstruct your view, we've been allowing them.snowborder714 wrote:What is the rule (if any) for camera mounts? I have a heavy duty suction cup mount that I'd like to use.
Great! I've got you on the list. just need your real name, and you're all set. Thanks.krang00 wrote:I'm new to Nico - already registered for Carlisle P&S and DEFINITELY in for some drifting that weekend! Let me know if there's anything else needed, otherwise we'll see ya there!
You are on the list.naladude911 wrote:Thought I would register as a spectator. Im not 100% sure if my parents will let me come because its a 4 hour drive but I will try my best.
He's now on the list.snowborder714 wrote:
Can you please add Tyler Smith to the pit access list please? Thanks!
how bad is the crack?shally2186 wrote:so its looking like Im not bringin my S14.5.. instead ill be bringin the new DRIFT Slut so i can DRIFT.. The windshield is cracked..Wanna make sure it passes tech..
Yep, We're hoping to do a tech/registration session at the Holiday Inn Mechanicsburg Friday afternoon just like last year, figure about 3pm until 6. That would be great if you can come down and help out. Thanks.EvoTyler wrote:Are you going to be teching cars on Friday like last year? Also if you need helping for anything on Friday I will be available, only working a half day.
You just signed up by posting here. I now have you on the list, All I need from you is your real name, so we can verify it when you arrive.rightcoastimports wrote:how do i sign up?
Many folks are staying at the holiday inn mechanicsburg. It's about 20 minutes from the fairgrounds. Should be a popular NICO social spot. We also doing early bird registration/tech there on Friday afternoon. There might be some folks willing to take on roomates. There are also several places to stay closer to the Fairgrounds, all different price ranges.. Most of them are on Carlisle Pike.flohtingPoint wrote:I'm guessing I need to start thinking about where to find lodging. Anyone with some suggestions?
I just added them to the list. And the seat set up is entirely up to you. Whatever makes you comfortable.Sijonda wrote:Hey Bubba1. Just found out I got a few people coming along with me.
My cousin Zach Shaub and my girlfriend Chelsea Hartley.
Is there a specific seat setup I need to be in (seat strait up or can it be laid back). I'm 6'3" and 240's aren't exactly tall.
Sorry,best pix i could get tonight.. thats from inside the car.. make the image bigger and look @ the crack.. its spidered off into like 4 cracks.. not like itll break out..Bubba1 wrote:how bad is the crack?
