Let me start by saying, I know this doesnt classify as a Z car, but where else WOULD it classify? I associate myself with the older car crowd (20+ year old chassis) and have personally owned a 1988 300zx NA (Wicked little car).
Anyways, this has been my project of the last two summers.. It has consumed my every day and night. Please feel free to ask questions.
I hit some major roadblocks with chassis work. I am by no means a body man, and barely have 3 months of mig experience under my belt (without shielding gas).. I will let the pictures do the talking.
I am doing a toad conversion on the front end using grand prix headlights. In this picture it shows how I am attempting to blend the headlight panels into the hood.
I re-enforced the bottom of the headlight panels with strips of metal, and made certain the body fill penetrated all the way through so that there was a good, solid base to work with. The hood now feels like one piece, and it very very strong.
Here is the 240 subframe which we pulled off the 240 parts car. We swapped 300zx (Z32) 5 bolt hubs onto it.. Having some trouble getting the axles back on, and my friend broke one of the CV boots, so they will need servicing.
Hub close up/differences.
We drilled through the rear crossmember (trunk member) and passed all thread through it. This is used to sling the 2 rear bushings of the 240 suspension assembly. This picture is deceptive.. Literally about 12 hours of work is all on that one beam.. Measurements, drilling, re-drilling, adjustments, more measurements... Sigh...
This greddy intake manifold will simplify the intake ducting. It is a work of art, and I paid out the nose for it. It makes the engine look killer though.
The bane of every engine swapper's existence: The wiring. This is the soon to be blended lower engine harness. I am using the 200sx starter relay, oil pressure sensor clip, alternator plugs, and excitation (ignition) wire.
Sideways engine mount. I am using the 240sx crossmember, but it needs to be drilled out to work as it is longer than the 200sx member. The 240sx crossmember MUST be used with these mounts as the tabs use the slope on the upright bits as a support, and on the 200sx one there is too much torque applied to it. It would make sense if you saw them side by side. I promise.
240sx coupe dash cluster. With digital display and Heads Up Display. I am using this because it accepts a digital speedometer signal, and just generally looks cool. Fitment isnt that great though.. I can do better.
Left = stock RB25det throttle bodyRight = VH45DE throttle body (infiniti Q45) it bolts right up to the greddy intake plenum
90mm of pure throttle. It has a slide throttle which accelerates throttle response in the upper power ranges. Pretty cool stuff. TPS sensors are NOT interchangeable (they are if you have a series 1 Rb25det, or RB20det) so I must manually wire the TB (only 3 wires).
Size it up. I can fit my arm inside the plenum.. As can a grapefruit.
The floor of the trunk. We must weld these shock towers in place due to the fact that the 240sx uses a shock assembly, and not an independant spring and shock. This is gonna be really really tough.
I reinforced the floor because I wasnt happy with the 1/8" thick steel supporting the entire subframe.
I messed this one up. Those are actually the FRONT 240sx calipers, along side the rear rotors.. The shiny bits are the 300zx rear rotors and calipers. They are HUGE. I have the e-brake assembly on order. The ebrake uses a shoe type brake INSIDE the rotor hat to prevent rotor warping.. It's quite intricate (and expensive).. This is why I need that brake bias valve.
Left = 1992 maxima caliperRight = 1989 240sx caliperNot a whole lot of difference here, but I couldnt afford 300zx calipers at this time, and I will probably be getting F50 brembos once I have saved up enough. I will be using altima rotors. I am sticking with 4 bolt in the front.
Much larger pad surface on these calipers.
Custom steering wheel. I welded a 240sx spline to it. :w00t:
The piece of 240sx transmission tunnel we need to use. The aftermarket mounts we have dont even come close to fitting the 200sx bolt holes. AND the 200sx tunnel is too narrow (mounts are too fat).. More chassis modifications.
I have some pictures of the test fit, but nothing very recent.. We have to lift the car into the air and put it ONTO the engine, but that there are no rear wheels we cant really move the car around.
UPDATES! I dont have picture of my front suspension, but I totalled the cost for it alone, and it's in the area of 1800$.. I shat my pants after I counted...
Here we go:
Properly toed wheels thanks to fully adjustable S13 tie rods, bolted to an S12 steering rack which sits atop an S13 crossmember. Wheels are RTX unknowns, 17x7 with a fwd offset. I've purchased 1/2 wheel spacers to compensate.
Old VS new, S12 tie rod on left, Brand new BING's fully adjustable tie rod on right, picture taken without the tie rod end.
Fuel pumps. Walbro is sitting inside cage (not tied down yet), S12 is on left. As you can see, the trunk had water sitting in it and has lots of surface rust.. Nothing a brillo pad + tremclad cant fix.
Ah yes the EPIC hole in the transmission tunnel. Basically what I am doing is welding in a piece of S13 tunnel to accomodate the transmission. This is partly due to how close I am mouting it to the firewall.
Me welding the rusty spots on the frame with patches.
To position the rear shocks, we had to make reference to the factory mounting locations. Essentially we built a jig which could be placed on the shocktower. It's tip would reference to very top and dead center of where the coilover need sit. We used an S13 with factory mounting locations: it was conveniently located right next to the S12.
The car.
It's neighbour.
STARTUP!
Video quality isnt the best, it was a cell phone..
http://www.youtube.com/watch?v=qsxsbGb7iLY
The sudden "Whoa whoa stop it" and discussion on the metal shavings is no cause to be worried. It was the cam angle sensor - somehow it was rubbing against the cam gear bolts.. I took it off, cleaned it up and its fine..
I'm the guy in the red shirt whos running around.. My favorite line "Lets go get beers, guys".
Engine is messy with wires and hoses and **** like that, but this is of course still a work in progress.
Wow.. That was tiring.
-Dan
