2009 Nissan Rogue Stereo Panel not working.. pls help
usual
Car: 2009 Nissan Rogue S
Hi Everyone
I just bought 2009 nissan rogue.. and the stereo panel has stopped working. The Radio is working but is stuck on one channel and none of the buttons work. I cannot change it to CD and AUX or change channels. all the buttons are non responsive. PLS HELP
Thanks
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
usual wrote:Hi Everyone
Thanks
You just purchased it from whom? A private seller? A new/used car dealership? Did it come with a limited warranty? Have you tried contacting the seller?
usual
Bought it from used car dealer and I called him right away. He asked me to come down and So he can fix it, but the problem is it couple of hours drive.
Rogue One
2022 Honda Pilot SE
usual wrote:Bought it from used car dealer and I called him right away. He asked me to come down and So he can fix it, but the problem is it couple of hours drive.
Option 1) Check for loose connection. Here's how to remove the stereo: http://nissanhelp.com/diy/rogue/project ... cedure.php
If it's not a loose connection, you'll have to replace it (at YOUR expense): panel-removal-help-for-stereo-t492512.html
Option 2) Take it back and let them deal with it.
usual
Thanks I am taking it back to the dealer on saturday.
Rogue One
2022 Honda Pilot SE
usual wrote:Thanks I am taking it back to the dealer on saturday.
Ok. I know it probably was not the option you were hoping for. Anyway, take some time to go over your vehicle and note any other issues that you may need to bring to their attention. There were quite a number of Technical Service Bulletins (TSB) issued for the 2009 Rogue http://www.automd.com/tsb/nissan_m/rogue_mm/2009_y/ You may want to make sure they have been taken care of, so make sure to talk to them about these as well.
zengshengliu
Car: 2008 Nissan Rogue SL
Quick thought:
Did you check to see if one of the button is stuck?
If one if them are stuck, then you can't press others until that one is "released" (I think)
Just a quick thought before you heading out for the long drive.
Return to “Rogue Forum”
