ae7456t »
https://forums.nicoclub.com/ae7456t-u172554.html
Thu Oct 12, 2017 6:14 am
Good luck with the shop...A couple of notes from my experience ...
1. My transmission shop was ok, but, in hindsight, I should have gotten multiple quotes
2. The approach from them was to check out the transmission for "free", at which point they will likely confirm what you already know...Then they offer to remove the transmission and inspect it for ~$500, at which point, you are somewhat committed, unless you want to have the car towed elsewhere...If you don't like what they tell you, they will charge you another $500 to reinstall. Not the end of the world, but once they remove the transmission, your options get a bit limited.
3. Only other word of advice is to get them to replace the rear main seal on the engine while the transmission is out...Easy enough to do, and worth it since it is exposed, anyway.
If you decide to go the DIY route, you have my utmost respect...I contemplated that, as well...Does not seem that hard, just a little heavy and a bit of a challenge to access all the necessary parts...Let us know how it goes!
