ae7456t »
https://forums.nicoclub.com/ae7456t-u172554.html
Tue Jan 31, 2017 3:16 pm
Quick update on the no reverse transmission saga...Which continues to go on...
Long story short, the first used transmission was DOA (pump wouldn't spin), so was never installed. I got a second, used replacement for free from the company that sold it to me (tremendous customer service!!!).
The second transmission looked good, got installed, but threw a P1757 code (Front Brake Solenoid), among others, once installed...No problem, the Valve Body in my old transmission was still good, so swap it into the 2nd used transmission.
That worked like a charm...They even called to have me pick up the car, then as they were pulling it to the front of the shop, they got a barrage of error lights...Tire Pressure Waning (!), VDC Off, ABS, Brake, Slip, AWD. In addition, the Tachometer does not register and the gear selector area is blank. Even more, the headlights turn on, even when the switch on the turn stalk was in the "Off" position. There are a few other electrical gremlins, too, but you get the picture.
Needless to say, the transmission shop is out of its depth with this happening, so I am searching like crazy to find a cause. The closest I can find is an electrical issue with the battery/IPDM. It looks like this is typically related to water in that area (we have not had that much rain, lately), so not 100% sure, but trying to hold out hope that this 3 week circus will end successfully.
Any other theories are always encouraged and welcomed!
I will continue to update, should anyone else find themselves in the same predicament.
