2009 240Z build
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
A quick update.
Decided to drop the RB in for a test fit. I ended up leaving the clutch out, so the engine/transmission went together real easy. This was more of a dry run to see WTF .
Got a little ahead of myself and left the shifter on. Quick snap ring removal, shifter out, and I was on my way.
Ta-Da!
Gotta hand it to the guys at Mckinney, they know there stuff.Thanks Mack!
Shifter even lines up!
That's it for now. Got to jump on a plane headed for Dallas.
nissan_star
Car: 2000 maxima se and 1993 240sx vert (5sp!!!)
whenever you post it like Xmas comes early
sek8031
Car: 1980 280zx
AZ89two4Tsx
What do you plan on doing suspension wise with that beast?
Logan76
Car: Junk
I would give a left nut to be able to tig like that mmmmm.
spooled240
Car: kouki s14
I think only God can weld better than that guy
man have I been missing out! But I'm updated so no worries
no vtec 4me
props for taking on such a project
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
Quick update.
I got the supports for the brake/clutch master cylinders made and installed.
Not too bad of a welding job. Not the best looking, but really strong.
Here it is with the pedal bracket removed. I made it so the whole pedal assembly can be dropped out the bottom and the support left in the car. Might come in handy . I plan on using the remote resevoir so there is plenty of room for those remote fittings.
Lots of room up here now.
Before
And after
chitownguy
Car: 74 260z and 85 325e
Nice I plan on going with the same brake/clutch setup with my car. Can't wait to see this one finished.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I've been considdering the new pedals wiht dual masters as well (but I was gonna run forward masters) I just can't get my head around how the pedals @" to the left would feel, I thought the stock pedals felt natural
so what bore diameters are you going with on the masters?
sek8031
Car: 1980 280zx
Also, what are you going to do with that surfboard and rack, if you haven't already junked it?
Colorado Kidd
Car: Datsun 260z
putting the car back together is the fun part, the disassembly can get old
ComicsCanucksCars
Car: 88 Nissan 300 ZX
Man - read this build thread for the 1st time, (1st time for me to stumble across this board,) and WOW - what a beauty!
Lots of cool stuff going on in your garage........ can't wait to see more!
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
sek8031 wrote:Also, what are you going to do with that surfboard and rack, if you haven't already junked it?
Still got the board and rack. Hansen board, Gerry Lopez signature series. It needs work. I'll get to it.
evildky wrote:I've been considdering the new pedals wiht dual masters as well (but I was gonna run forward masters) I just can't get my head around how the pedals @" to the left would feel, I thought the stock pedals felt natural
Funny thing about that. I tried splitting the pedals on either side of the steer column, but there was little or no room for my foot to be only on the gas pedal (unless I wear the pumps, but we won't go there). It had to be left of center column. I think it is what you get used to, and I can learn. I think the heal/toe technique is easily possable as long as the gas pedal isn't too far away.
I have the 7/8" bore for the brakes and 3/4" for the clutch. Lots of research done and I should be good. Worst case is that I have to get bigger bore and those can easily be swapped out. The cool thing is I can play around and get the pressure/bias/feel perfect with this sort of setup.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
This Z is looking scary.
evildky
06 Nissan 350Z GT
you are running 2 7/8 master for the brakes!? you are gonna have a heavy rear bias to tune out, so I guess you are gonna run a prop valve i conjunction wiht the ballance bar?
S13ManBoy
Car: 89' 240sx fastback
more more more ! great build so far anyways what do you think your final color is going to be?
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Damn Gordon, your pedal set up is SWEET!
Redbeauty84ZX
That oil pan looks gorgeous....so when you say the Z31 pan do you mean the factory 84-89 300ZX oil pan fits the RB26? Is there some fab work needed???
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
Redbeauty84ZX wrote:so when you say the Z31 pan do you mean the factory 84-89 300ZX oil pan fits the RB26? Is there some fab work needed???
Japanese domestic market (JDM) Z31 was the 200Z and you could get it with a RB20DET engine. It was the marketed as the 200ZR. It had a rear sump oil pan that will fit on the RB26. The oil pickup works too. It was the pan of choice for swappers because it was cheap and available.
S13ManBoy wrote: what do you think your final color is going to be?
I wanted black or Laguna Sega Blue. I am finding them both a little over done and starting to get confused on the color. I'll figure something out.
evildky wrote:you are running 2 7/8 master for the brakes!? you are gonna have a heavy rear bias to tune out, so I guess you are gonna run a prop valve i conjunction wiht the ballance bar?
From what I have read, the master bore diameter should be based on the number and diameter of the brake caliper pistons (displacement). This should be evenly balanced so the same stroke (front and rear master) should engage the brake pads at aprox the same time. After this happens, the bias adjustment in the pedal setup will increase the "FORCE" then applied to the pads. I should be OK with the 7/8". I'll let you know after turn 1
evildky
06 Nissan 350Z GT
ummmm...no, you can email tilton your car specs, weight, pistons # and size and they'll tell you what diameters you should be running, generally the rear culinder is gonna be smaller, with your setup your rears are gonna lock up even with the ballance bar adjusted all the way out
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
evildky wrote:ummmm...no, you can email tilton your car specs, weight, pistons # and size and they'll tell you what diameters you should be running, generally the rear culinder is gonna be smaller, with your setup your rears are gonna lock up even with the ballance bar adjusted all the way out
Mmmmmm Maybe.What rear brakes am I going with? What size diameter rotor?What are the number of pistons and diameter? What is the brake pad composition?
Lots of variables. I agree that the balance bar is for fine tuning. I got the tables for "caliper piston displacement/master cylinder size" based on caliper type, calipers per master cylinder, piston diameter, number of pistons per caliper and everything indicates I should be in the ballpark. The cool thing with this setup is that it is adjustable. I should be able to swap out masters as well.
evildky
06 Nissan 350Z GT
I'm running the JSK willwood setup and tilton recomended a .7 front and 13/16 rear
Vivibig
cool beans man. Its tough to work on a car in these midwest winters
mikeith
Car: 73 240z
gmac708 wrote:
^^^ l l l VERY jelous!
try running the 13" rotor w/ 6 piston setup from arizonazcar up front and their 12.2" rotor w/ 4 piston caliper in back. i would think that would fix having the same size master for front and rear
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
I got my oil pan from Ripps today.
Rob did an awsome job!
It fit like a glove.
New dipstick location.
Pictures do not do it justice, it looks 10X better up close.Amazing
JDMZ32
Car: 1991 Nissan 300ZX NA slicktop 5spd red
just found this thread tonight! i loved your S14 build thread for your son and this one is looking just as great! 2200-pound S30 + RB26DETT = can't even imagine how awesome the finished product will me. wish my Z33 was that weight! then my VG30DE might actually be worth something :P.
improved1
Car: Cursed 1990 300zx
update???
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
improved1 wrote:update???
Went to Carlisle with the kid for the weekend. Some stuff out for powdercoating Mothers day
I will get back on it soon!
improved1
Sorry hehe. didn't mean to be rude with the WTF. Just look forward to loggin on, on sundays and seeing the weekend update keep up the good work
Return to “Datsun Z Forum”
