read somewhere that you need to cut the line to the parking brake and ground it. theres a thread here somewhere explaining it for an Armada, which should work for the QX as well, if im not mistakenbkelly wrote:I get the DVD to play up front when the vehicle is stopped , in park, and e-brake applied. I have been able to make mods to get it to play while moving except the e-brake is giving me a challenge.
For anyone reading this, you can't simply cut the wires and ground them if you have Navigation. You need to have these two wires on a DPDT switch so that you can flip back to a "stock" position so the navigation can function properly.hockeyguy21 wrote:i grounded both the speed sensor and parking brake wire together, and i have no problems.
well, the navigation seems to be lagging now and i need to see if thats part of what a cut because im honestly not sure
