Timmbo
Armada/QX56/Murano/EX35 Moderator
'08 Nissan Armada LE & '08 Nissan Altima 3.5 SE
Green Bay WI
11-20-2007
| « Re: 08 Aramda Non-Nav TV ByPass (236697) | 6:07 PM 12/26/2007 |
Nice job so far, have you checked out the service manual for the '08 yet?
'08 Nissan Armada LE (Timberline) & '08 Nissan Altima 3.5 SE (Dark Slate)
236697
08 Nissan Armada
Miami FL
9-29-2007
| « Re: 08 Aramda Non-Nav TV ByPass (Timmbo) | 6:36 AM 12/27/2007 |
Yes check service manual for 08 but doesn't state the wire for the speed sensor....
Timmbo
Green Bay WI
11-20-2007
Sit tight on this one, I have done a lot of research, and I have yet to find anyone that has completed this mod. I will be saying good bye to my '04 QX56 and getting an '08 Armada in the next month or two. I am hoping by then someone successfully completes this mod, and I will be able to confirm it myself, I will be sure to keep you posted on any info.
236697
08 Nissan Armada
Miami FL
9-29-2007
| « Re: (Timmbo) | 10:48 AM 12/28/2007 |
well there is to wires that need to be cut one is the e-brake wire wich needs to be grounded inwhich i have done the other is the speed senor wire that need to be cut or put on a switch.......
236697
08 Nissan Armada
Miami FL
9-29-2007
| « Re: (236697) | 3:28 PM 2/21/2008 |
has any figured this out yet..........
Timmbo
Green Bay WI
11-20-2007
| « Re: (236697) | 5:46 PM 2/21/2008 |
No luck yet, I have been following this here and at other sites, still no luck anywhere! Please let me know if you find anything out and I will do the same!
Alegre323
Los Angeles CA
2-25-2008
| « Re: (Timmbo) | 12:44 AM 2/25/2008 |
can this work on a 05 QX56? (nav)
Timmbo
Green Bay WI
11-20-2007
| « Re: (Alegre323) | 7:36 AM 2/25/2008 |
| Quote, originally posted by Alegre323 » | | can this work on a 05 QX56? (nav) |
The '05 models are actually very simple if you have the Nav and DVD packages. The '08 and newer already have the feed from the DVD player being sent to the Nav screen, however, you can't watch on the Nav screen unless the E-Brake is on, and the vehicle is in a stationary position. I previously owned an '04 QX56, and all I had to purchase was the switch unit from TV and Nav 2 Go and installed that, with a switch from Radio Shack (to flip the Nav screen from Nav to DVD) and then you can watch DVD's on the rear and front Nav screen, even while you are cruising down the interstate, of course that is for the passenger in the passenger seat, not the driver!
Alegre323
Los Angeles CA
2-25-2008
| « Re: (Timmbo) | 10:06 AM 2/25/2008 |
can you link me directly to this?| Quote, originally posted by Timmbo » | The '05 models are actually very simple if you have the Nav and DVD packages. The '08 and newer already have the feed from the DVD player being sent to the Nav screen, however, you can't watch on the Nav screen unless the E-Brake is on, and the vehicle is in a stationary position. I previously owned an '04 QX56, and all I had to purchase was the switch unit from TV and Nav 2 Go and installed that, with a switch from Radio Shack (to flip the Nav screen from Nav to DVD) and then you can watch DVD's on the rear and front Nav screen, even while you are cruising down the interstate, of course that is for the passenger in the passenger seat, not the driver! |
Timmbo
Green Bay WI
11-20-2007
| « Re: (Alegre323) | 1:31 PM 2/25/2008 |
http://www.tvandnav2go.com/in-car-dvd.html I actually had the unit where you cut your own wires, NOT the plug & play model. I like this one because it allows you to make the connection underneath your passenger seat where the Nav DVD rom drive is located. That is much easier than trying to rip your dash apart to get to the back of the Nav Screen. The one thing people had an issue with is when you watch a DVD, you would still see the HVAC display on the bottom portion of the screen while you were watching the movie, but by making the connection at the back of the Nav DVD rom drive, all you have to to is hit the "Route" button, and all you will then see on the screen is the movie you are watching......the cool thing is if you raise the temp or change the vent or something, it shows up for a few seconds, and then disappears again. I was very happy the the TV and Nav 2 Go unit.
Alegre323
Los Angeles CA
2-25-2008
| « Re: (Timmbo) | 2:46 PM 2/25/2008 |
| Quote, originally posted by Timmbo » | | http://www.tvandnav2go.com/in-car-dvd.html I actually had the unit where you cut your own wires, NOT the plug & play model. I like this one because it allows you to make the connection underneath your passenger seat where the Nav DVD rom drive is located. That is much easier than trying to rip your dash apart to get to the back of the Nav Screen. The one thing people had an issue with is when you watch a DVD, you would still see the HVAC display on the bottom portion of the screen while you were watching the movie, but by making the connection at the back of the Nav DVD rom drive, all you have to to is hit the "Route" button, and all you will then see on the screen is the movie you are watching......the cool thing is if you raise the temp or change the vent or something, it shows up for a few seconds, and then disappears again. I was very happy the the TV and Nav 2 Go unit.
looks good... def. going to order it :D
Timmbo
Green Bay WI
11-20-2007
Let me know if you have any questions when you are installing it.
236697
08 Nissan Armada
Miami FL
9-29-2007
Any more info on this.........
236697
08 Nissan Armada
Miami FL
9-29-2007
| « Re: 08 Aramda Non-Nav TV ByPass (236697) | 6:28 AM 7/2/2008 |
I found one solution for the front display......http://navtv.selectinterface.c...id=12
Timmbo
Green Bay WI
11-20-2007
| « Re: 08 Aramda Non-Nav TV ByPass (236697) | 7:15 AM 7/2/2008 |
Here is what I found. These are the complete instructions on how to be able to view your DVD's on the front Nav screen while the vehicle is in motion. This will also work if you DO NOT have the DVD player and you are sending a feed through the Aux Inputs.  Half way down on the left side it says "from +12volt switch" That is the wire that will trigger your relays from the switch. I didn’t show the switch wiring, this will be different depending on what type of switch you have. If you have just a basic "un-lit" switch then one end will go to your switched 12volt source and the other end will go to the relays like I have shown. A good source for your switched 12volts is at the 12volt socket in the black pocket. this is a switched source and the relays are not passing any current so this power will be more than enough.. As far as relays, go into any audio shop and ask them for a basic 12 volt Bosch/tyco 30 amp relay. If they don’t have that then ask for a Potter & Brumfield 40 amp. This will be the same place that should have your standard 1amp diode. And usually will have a cool round rocker like I used.
GrillAg98
East Texas Texas
1-29-2008
| « Re: 08 Aramda Non-Nav TV ByPass (Timmbo) | 2:35 PM 7/9/2008 |
This is a pretty sweet mod. How does it differ from the QX56 wiring, etc? Did you just clip the speedsense and e-brake? I guess I'm not getting how the relay, pin 82 and 80 and switch all tie together. Forgive my ignorance.
Timmbo
Green Bay WI
11-20-2007
| « Re: 08 Aramda Non-Nav TV ByPass (GrillAg98) | 7:15 AM 7/10/2008 |
| Quote, originally posted by GrillAg98 » | This is a pretty sweet mod. How does it differ from the QX56 wiring, etc? Did you just clip the speedsense and e-brake? I guess I'm not getting how the relay, pin 82 and 80 and switch all tie together. Forgive my ignorance. |
I don't quite understand it all myself, but I know it works, and that is really all that matters. The QX56 and the Armada are the same for doing this mod.
236697
08 Nissan Armada
Miami FL
9-29-2007
| « Re: 08 Aramda Non-Nav TV ByPass (Timmbo) | 9:50 AM 9/14/2008 |
The above illustration is correct if you have the Navigation, but the system that does not include navigation is a little different. The procedure for Non-Nav 08 Nissian armada is to remove move the radio as shown above. The differance is in the radio itself and the pins. For the Non-Nav its pins 106 & 107. 106 - Ground Parking brake signal 107 - Ground Vehicle speed signal You do not need the relay's unless you want the option to switch back and forth from factory to modified. Just cut the two wires (be sure to leave enough wire from both the rear of the radio and the harness. MAKE SURE NO TO CUT THE WIRE TO SHORT OR YOU WILL BE SCREWED. Take the wires from the rear of the radio and ground them and you have the option of displaying movies on the front screen. If you dont want to display the movie in the front screen while driving just press the status button on the radio and it will display the default Nissan screen. To revert back to the movie press the DVD/AUX bottom under the FM/AM button and it will display the movie. Hope this helps everyone.....And the best thing about it is you dont have to spend money an any after market parts.
apatahunga
QX56 2005
Boca Raton FL
9-22-2008
| « Re: (Timmbo) | 8:29 AM 9/22/2008 |
Hello, I am new to the forum, I own Infiniti QX56 2005 with DVD, NAV and rear camera. It would be nice to be able to watch DVD in the front, but I would really love to disable park requirement for the NAV (GPS). Is there any way to do that?
BmoreQX56
2008 QX56
Baltimore MD
10-1-2008
| « Re: 08 Aramda Non-Nav TV ByPass (236697) | 8:07 PM 10/1/2008 |
Could you elaborate more on your comment regarding the cutting of the wires? Where do you cut them? How much length do you need to leave? How do you suggest to ground them?
Timmbo
Green Bay WI
11-20-2007
Welcome to NICOclub, thanks for visiting the Armada/QX56 Forum! Unfortunately there isn't much I can elaborate on, I have yet to personally perform this mod. Maybe in the coming months when I am not using my days off to go golfing! I would imagine any good clean metal framework should work great for the ground.
Blown284
'08 Infiniti QX56, '99 Mustang Cobra
Pasadena Md
10-20-2008
| « Re: 08 Aramda Non-Nav TV ByPass (BmoreQX56) | 1:09 PM 10/21/2008 |
| Quote, originally posted by BmoreQX56 » | Could you elaborate more on your comment regarding the cutting of the wires? Where do you cut them? How much length do you need to leave? How do you suggest to ground them?
Since you're close to me, have you figured this out? I'd love for my wife to be able to watch DVd's up front so leave be quiet and leave me the hell alone while I'm driving
bkelly
Infiniti QX56
Los Gatos Calif
11-2-2008
| « Re: 08 Aramda Non-Nav TV ByPass (Timmbo) | 7:45 PM 11/2/2008 |
I finally had a chance to follow your intructions on a 2008 QX56.Opening up pin #80 and#82 seemed to be correct however the e-brake is still overriding. If I ground the wire at the e-brake pedal I can get the dvd to stay on but the e-brake light and bell stay on while moving.I am close but need another idea.Any thoughts??
hockeyguy21
2008 Infiniti QX56, 2005 Honda Element
Fort Wayne IN
11-15-2008
| « Re: 08 Aramda Non-Nav TV ByPass (bkelly) | 4:31 PM 11/15/2008 |
anyone got this up and running? how has it turned out? im trying to figure out how to get this done on my dads infiniti qx56 and i am having trouble getting the first piece off since there is a clock there instead of that little "nook" or "hole" any words of advice from the people who have this done is greatly appreciated
Dads QX56 I Own A Customized Honda Element
hockeyguy21
Fort Wayne IN
11-15-2008
| « Re: 08 Aramda Non-Nav TV ByPass | 10:34 AM 11/27/2008 |
I have completed this mod, and im sorry i didnt take any pictures after unplugging the battery, my dads navigation does not move on the screen. i assume this is something that happened since i unplugged the battery, but i am not positive. we will be taking it in tomorrow to checkbut i was just cruising down the road at 45 mph watching kung fu panda this mod gets
236697
08 Nissan Armada
Miami FL
9-29-2007
| « Re: 08 Aramda Non-Nav TV ByPass (bkelly) | 5:16 PM 12/15/2008 |
Have you grounded the wire correctly behind the radio....
bkelly
Infiniti QX56
Los Gatos Calif
11-2-2008
| « Re: 08 Aramda Non-Nav TV ByPass (236697) | 7:20 AM 12/16/2008 |
Once I installed the 5 prong relays and grounded the brake wire at the back of the head unit everything works great. This is the best mod you can make to the 2008 QX56.
Timmbo
Green Bay WI
11-20-2007
| « Re: 08 Aramda Non-Nav TV ByPass (bkelly) | 12:56 PM 12/20/2008 |
I am going to finally be performing this mod on my '08 Armada. The only questions I have are regarding the relay.What exactly does the relay do? How do I know which wires to connect where on the relay? What relay is the best to use for this mod? Where do you suggest getting the relay from? (does Radio Shack have this?) Thanks so much for your feedback, I really appreciate it, I will be able to better assist others with this mod on the forum as well.
Happy Holidays!
GrillAg98
East Texas Texas
1-29-2008
| « Re: 08 Aramda Non-Nav TV ByPass (Timmbo) | 1:40 PM 12/31/2008 |
Take pics and write details. I need to do this and knowing me, I'll probably eff it up.
Blown284
Pasadena Md
10-20-2008
A comprehensive write-up would be greatly appreciated. Seems there is info scattered...........
hockeyguy21
Fort Wayne IN
11-15-2008
| « Re: 08 Aramda Non-Nav TV ByPass (Timmbo) | 3:57 PM 12/31/2008 |
| Quote, originally posted by Timmbo » | | I am going to finally be performing this mod on my '08 Armada. The only questions I have are regarding the relay. What exactly does the relay do? How do I know which wires to connect where on the relay? What relay is the best to use for this mod? Where do you suggest getting the relay from? (does Radio Shack have this?) Thanks so much for your feedback, I really appreciate it, I will be able to better assist others with this mod on the forum as well.
Happy Holidays! |
the relay and switch, as i assume (since i didnt use it) was just to power the rocker switch, which allowed the speed sensor to either be turned on, or turned off, allowing the screen to play movies. so the switch is so you can go from "modified" to "unmodified"
hockeyguy21
Fort Wayne IN
11-15-2008
| « Re: 08 Aramda Non-Nav TV ByPass (bkelly) | 4:02 PM 12/31/2008 |
| Quote, originally posted by bkelly » | | Once I installed the 5 prong relays and grounded the brake wire at the back of the head unit everything works great. This is the best mod you can make to the 2008 QX56. |
hows the lag on the GPS? it seems without the relays my dads GPS system lags a whole lot.
Timmbo
Green Bay WI
11-20-2007
| « Re: 08 Aramda Non-Nav TV ByPass (hockeyguy21) | 8:07 PM 12/31/2008 |
| Quote, originally posted by hockeyguy21 » | hows the lag on the GPS? it seems without the relays my dads GPS system lags a whole lot. |
The lag is almost a non-factor. I just completed the mod 4 days ago and usally within 15-30 seconds the Nav catches up when you flip the switch back.
hockeyguy21
Fort Wayne IN
11-15-2008
| « Re: 08 Aramda Non-Nav TV ByPass (Timmbo) | 9:49 PM 12/31/2008 |
| Quote, originally posted by Timmbo » | The lag is almost a non-factor. I just completed the mod 4 days ago and usally within 15-30 seconds the Nav catches up when you flip the switch back. |
maybe i should install the switch then. howd ou wire that switch up?
Timmbo
Green Bay WI
11-20-2007
| « Re: 08 Aramda Non-Nav TV ByPass (hockeyguy21) | 7:50 AM 1/1/2009 |
| Quote, originally posted by hockeyguy21 » | maybe i should install the switch then. howd ou wire that switch up? |
I don't know that the switch would make it go any quicker. The other problem is that you would also have to place a switch in the e-brake wire, and just doing the switch will cause the "BRAKE" light to stay illuminated on your dash when you are watching video on the front screen.....that is unless you simply ground that wire instead of placing it on a switch, but then when you actually have your e-brake on, the "BRAKE" light will NOT be on. Just some things to think about.
airwolf09
Raleigh nc
1-11-2009
| « Re: 08 Aramda Non-Nav TV ByPass (236697) | 5:33 AM 1/11/2009 |
| Quote, originally posted by 236697 » | | The above illustration is correct if you have the Navigation, but the system that does not include navigation is a little different. The procedure for Non-Nav 08 Nissian armada is to remove move the radio as shown above. The differance is in the radio itself and the pins. For the Non-Nav its pins 106 & 107. 106 - Ground Parking brake signal 107 - Ground Vehicle speed signal You do not need the relay's unless you want the option to switch back and forth from factory to modified. Just cut the two wires (be sure to leave enough wire from both the rear of the radio and the harness. MAKE SURE NO TO CUT THE WIRE TO SHORT OR YOU WILL BE SCREWED. Take the wires from the rear of the radio and ground them and you have the option of displaying movies on the front screen. If you dont want to display the movie in the front screen while driving just press the status button on the radio and it will display the default Nissan screen. To revert back to the movie press the DVD/AUX bottom under the FM/AM button and it will display the movie. Hope this helps everyone.....And the best thing about it is you dont have to spend money an any after market parts.
do you have the picture of how the wiring connect to the relay, switch and pin? is this a 3 pins relay or 4 pins relay. greatly appreciated if you have the wiring diagram of how all the wires go to the switch and relay.
airwolf09
Raleigh nc
1-11-2009
| « Re: 08 Aramda Non-Nav TV ByPass (bkelly) | 10:51 AM 1/11/2009 |
can you please post how you get the wiring connected to the relay and the switch? and where can i get the relay?
Timmbo
Green Bay WI
11-20-2007
| « Re: 08 Aramda Non-Nav TV ByPass (airwolf09) | 12:10 PM 1/11/2009 |
| Quote, originally posted by airwolf09 » | can you please post how you get the wiring connected to the relay and the switch? and where can i get the relay? |
Welcome to NICOclub! Glad to have you here in the Armada/QX56 Forum! When I did this mod, I purchased the relays pre-wired with the switch from a gentleman named Shane. He owns a company called Tintmasters in the Dakotas. He will be posting a message soon here, but if you would like to order the relays with the switch (including detailed instructions), please e-mail him at: tntmstr@aol.com He charges about $50 (includes shipping) and trust me, this makes it an extremely easy mod to perform!
tintmasters
many!
Fargo ND
1-17-2009
| « Re: 08 Aramda Non-Nav TV ByPass (Timmbo) | 9:34 AM 1/17/2009 |
Thanks for the props Timm. the relay pack I make will have more detailed instructions than those I have already posted. If you are a 12volt savvy person, the instructions I have given will make it a snap. If you are a novice, the instructions I will supply you with will make it simple. Any one interested in the mod, the pricing is as follows. $50 LED round rocker switch Blue or Red LED (13/16" hole) $45 Standard mini toggle switch. Pricing includes Priority Mail If you choose to purchase the mod, please paypal me at tntmstr@aol.com In the info bar please include what type and/or color of switch and what type of Nissan you have, with or without NAV. ***** This modification is to be used as a novelty item and/or for address entry into the navigation by a passenger, while the vehicle is in motion. I do not condone operation of a vehicle while being distracted by full motion video. By sending funds for this modification you are taking full responsibility for YOUR actions. This relay pack can be used for many other functions. What you choose to do with it is your option. This modification is guaranteed to work. But I cannot guarantee your ability to install it correctly. I will take no responsibility for any incorrect installation. If you choose the round rocker switch you will be required to brill a 13/16" hole in a dash panel. If you do not have access to the correct size step bit for this I will not take your modification back. You will need to re-order a new modification with the small toggle switch. Please make sure you can acquire the correct tools you will need for the job. Please check your local and state laws and understand your consequences.
| First 1 2 3 > Last |
