2007 Nissan Versa Problem
Urq
Car: 82 Ur Quattro & 07 Black Versa SL CVT.
Thanks for keeping us updated!Did you get a list of the codes it pucked up?
ehandlr
Car: 2007 Nissan Versa
Urq wrote:Thanks for keeping us updated!Did you get a list of the codes it pucked up?
Unfortunetly not. I was reading over the techs shoulder as he ran the test. He explained in lamens terms that it wasn't sending the accelerate data to where it needs to go. So the car doesn't know to speed up when the gas pedal is pressed.
ehandlr
Update #2
So Nissan called my wife today. They drove the car around and recreated the problem yet again. They believe that some "computer control unit" is bad and needs replaced but it will take a couple of days to get ordered in. Not only that, but we need to have both of our keys sent back to be reprogrammed since we have that package to where we only need the keys on our person to start the car.
Only bad news is when he said "We hope this fixes the problem."
Rockhound
Car: 2007 Nissan Versa 1.8 SL HB CVT
2008 Mazda3 GT
ehandlr wrote:Update #2
I guess the same "computer control unit" governs the iKey? At least it sounds like they're making progress - hopefully this is the answer. Keep us posted.
nissantech06
Car: 2007 Nissan Sentra S 2.0
Yes. We have had these modules replaced on TWO Versas that came off the truck brand new and wouldn't start or run.
ehandlr
Alright all...seems the car is finally fixed. It was the computer control unit. It took them over a week or so to get it all repaired. I still had one issue with starting the car one time with 2 extended turns of the key.
Now...to get my 100 dollars back :P Thanks for all the help everyone.
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
ehandlr wrote:Alright all...seems the car is finally fixed. It was the computer control unit. It took them over a week or so to get it all repaired. I still had one issue with starting the car one time with 2 extended turns of the key.
as in you had to crank for a while, stop trying, then crank again before it started?
Hate to tell you this, but your fuel pump is now bad... See this thread ----> zerothread/261625
ehandlr
thanks for the info. This problem was very bad before the computer swap...taking up to 4 turns to start the car. I've only it happen once or twice since I've gotten it back and it only took 2 turns. We will keep an eye on it and if it becomes problematic..we will send it back.
