Deke40
07 Nissan Versa SL HB 08 Nissan Altima 3.5 SL
Freeport Texas
3-31-2007
| « Re: Start-up problems at 400 miles? (seize) | 5:10 AM 7/2/2007 |
I would definitely postpone the trip until you take the V in to the dealer.I have had and have heard of starting problems but not of the dying after starting. My own SL has had a problem at different times of not cranking on the first try and then it always cranks. The salesman I bought it from is having the same problem. I haven't taken mine in yet as is always starts after this problem and I have been on the lookout for others having the same problem. Get it to the dealer if you are feeling uduly apprehensive about the problem.
Take Care Deke ________________________________ 07 Versa SL HB-23,300 Miles-27.7 MPG Last Tank 08 Altima 4D SL 3.5
gotrice
2007 Versa S
MONROEVILLE PA
6-9-2007
| « Re: Start-up problems at 400 miles? (seize) | 5:17 AM 7/2/2007 |
I know this may sound silly, but what else do you have on your key chain with your car key?The reason i ask is that my car started up fine til i put the key on with my other keys. (LOL SOUNDS FUNNY) What was happening was that on my key ring, i had an electronic key fob.(keyless access) When it was close to my key, it wouldnt allow the car to start sometimes. The electronic key fob would interfere with the chip in the key. It took me a good day to figure out what the hell was going on. Hope this helps. If not, its just a long story in the wrong topic. LOL
gotrice
2007 Versa S
MONROEVILLE PA
6-9-2007
| « Re: Start-up problems at 400 miles? (gotrice) | 5:18 AM 7/2/2007 |
Oh yeah, if you read your manual, it tells you that you may want to put your key on a seperate ring. Also this is for all models.
Deke40
Freeport Texas
3-31-2007
| « Re: Start-up problems at 400 miles? (seize) | 6:14 AM 7/2/2007 |
Seize-Is your car actually running then dies or is it just turning over and not running? Because if your are blocking the signal from your key you will get a red key symbol and it will not turn over and a green one if the signal is getting through and it should start or do like mine and take a couple of tries to start.
seize
Versa SL HB
Minneapolis MN
6-4-2007
| « Re: Start-up problems at 400 miles? (Deke40) | 9:46 AM 7/3/2007 |
Deke:Yeah, it's turning over, and sometimes it goes but then dies. Sometimes it just turns and turns and won't start. The second time always gets it going, though. I took the trip against my judgement, so I'm taking it in to a dealer here. This sucks.
Deke40
Freeport Texas
3-31-2007
| « Re: Start-up problems at 400 miles? (seize) | 1:40 PM 7/3/2007 |
The last two days mine has been taking at least two tries to get it going. I found out today if I just keep it in the "crank" position it will crank but I was always taught this is not good for the starter as it will overheat it and eventually cause a failure from this extended cranking.I make a trip for the Nissan dealer yesterday and talked to one of the techs in the shop. He said he hadn't heard of this problem in the Versa but leave it with him and if they can't find it they then call Nissan with the problem. Going to leave mine with them next time I drive for them. Will keep you posted.
seize
Versa SL HB
Minneapolis MN
6-4-2007
| « Re: Start-up problems at 400 miles? (Deke40) | 2:50 PM 7/3/2007 |
I took it in to a helpful Nissan dealer here in Cedar Rapids. They checked it out and said it was a fuel pressure problem. They needed to order parts for it, either a fuel pressure gauge or the fuel pump itself. I don't know how reliable that information is, since I called my dealer (Luther Nissan) and they said that sounded pretty rare. Both service departments said they've never seen anything like it on a new Versa. The guy here in Iowa seemed to think it was a faulty part, but my car only has (now) 600 miles on it. I'm not really sure what to do, but I have to drive it back to Minneapolis today. I'm going to try not to stop at all, but that's going to be pretty difficult. Deke, I tried the crank-till-it-starts and it seemed to work for me, too, but it also goes against my better judgement. I would imagine it works the second time because it has the fuel from the first try, too. I know next to nothing about cars and don't know how skeptical to be toward all of this. Anyone had this problem before? Anyone have any idea how much it'll cost me? My Luther guy was real chatty, asking me how much I liked the car, you know, except for this whole can't-start-it-up-right thing. I do love it, but this is pretty annoying, especially because I work the holiday. Thanks for the help, guys.
bikeman
2007 Nissan Versa SL
Syracuse NY
5-29-2007
| « Re: Start-up problems at 400 miles? (seize) | 5:41 PM 7/3/2007 |
| Quote, originally posted by seize » | | my car only has (now) 600 miles on it. Anyone had this problem before? Anyone have any idea how much it'll cost me? |
First time I've heard of this problem. Why do you think it'll cost ya anything except your time?David
stevejonas1088
Nissan Versa Sedan
las vegas nv
7-3-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (seize) | 5:42 PM 7/3/2007 |
Almost always these kinds of problems are fuel related. You have to take into account your elevation and weather conditions. Just turn the key to acc position for 3-5 seconds and let the fuel pump, get fuel all the way to the injectors. I may sound silly for saying this and it is prolly out dated but works for me, on any other vehicle I have driven.
Deke40
Freeport Texas
3-31-2007
| « Re: Start-up problems at 400 miles? [Upd ... (stevejonas1088) | 6:30 PM 7/3/2007 |
| Quote, originally posted by stevejonas1088 » | | Almost always these kinds of problems are fuel related. You have to take into account your elevation and weather conditions. Just turn the key to acc position for 3-5 seconds and let the fuel pump, get fuel all the way to the injectors. I may sound silly for saying this and it is prolly out dated but works for me, on any other vehicle I have driven. |
I forgot to include in my post that I had been doing what you mentioned and it doesn't help at all. I have owned numerous autos with fuel injection and have never had this problem regardless of the weather conditions. I am not saying this couldn't happened I just haven't experienced it myself. What ticks me off is it will go for awhile with no problems then start all over again. The salesman that sold me mine bought one about the same time I did and he is having the same problem. It has never left me stranded yet.
01LTD
2001 Nissan Altima & 2007 Nissan Versa
DFW TX
12-30-2002
| « Re: Start-up problems at 400 miles? [Upd ... (Deke40) | 9:14 AM 7/4/2007 |
I'm having the same issues with mine. Just haven't had time to take it into the dealership. I only have the key and the keyless entry on my keyring. So who knows. just pisses me off since the car was new and it now only has 10K miles. Grrrrrrrr. Hasn't left me stranded though. Keep us updated on what happens.
EdKrull
Nissan Versa SL CVT
Dallas TX
7-6-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (seize) | 1:56 PM 7/6/2007 |
I am having the same problem, as is a friend who bought one recently. I have about 400 miles and they have about 800. Starts after keeping the key turned for 3-5 seconds.
newversa
stamford cT
7-8-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (seize) | 6:01 PM 7/8/2007 |
is this a common issue. my new versa has just 40 miles on it. purchased it less than a month ago. And now the key just wont turn for ignition. I checked the front wheels, etc. nothing that should cause it to lock. I am already thinking of trading it in. will i get the same value i bought it for? It a NMAC financed car. I dont want to be spending money, and going to the dealer every other month.
KimberKenobi
the Camel
Louisville KY
3-21-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (newversa) | 6:10 PM 7/8/2007 |
On my first V I went through a period where there was a starting delay (had to keep it turned over for longer than I'd like) but it went away... Surely all Vs can't be bad... I've had two so far and no trips to the shop (that weren't because people are retarded and apparently my car makes people forget to be intelligent) ... let me clarify, I've been back several times in reference to my paint protectant, my decals, and my dealer brands. In fact, I'd only have had one V if the salesman hadn't told me that the aftermarket sunroof was better than the factory sunroof. We'll see how the Camel goes after a 5,000 mile round trip in late August... but I've been really happy with the V so far...
| Quote, originally posted by EV » | | I'm going to say that happen on the 11th of never. |
| Quote, originally posted by Amanda » | | "If you don't have anything nice to say about someone, come sit next to me." |
Woogie
'08 Versa SL
Seattle WA
7-6-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (newversa) | 9:10 PM 7/8/2007 |
| Quote, originally posted by newversa » | | is this a common issue. my new versa has just 40 miles on it. purchased it less than a month ago. And now the key just wont turn for ignition. I checked the front wheels, etc. nothing that should cause it to lock. I am already thinking of trading it in. will i get the same value i bought it for? It a NMAC financed car. I dont want to be spending money, and going to the dealer every other month.
Not sure if this is a common issue, but if you trade it in, then you will NOT get the full purchase price back. The car is now considered used and depreciation has started to kick in. Assuming that you didn't pay more than MSRP, the value of the car is probably around 15%-%25 less than when you bought it. If you sell it yourself, you might get closer to what you paid, but probably not the full amount, especially now that the 2008s will be hitting the dealers in force soon. The car is still under warranty. The dealer has to fix it for free. Is this is the only problem? If so, then give the dealers a chance to fix it. It will cost you far less money to have the dealer fix the problem than to trade it in for another car.
Modified by Woogie at 9:26 PM 7/8/2007
Deke40
Freeport Texas
3-31-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (Woogie) | 5:17 AM 7/9/2007 |
newversa-My first question would be--Do you have the Intelligent Key opition?
GoodbyeCavalier
Versa 2007
Pasadena MD
2-8-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (Deke40) | 3:10 PM 7/9/2007 |
Im having the same problem, with I key, but if i keep cranking it will start, it always starts the second time, I havent noticed the red no key symbol, shouldnt be an issue, its always in my front pant pocket. It seems to do it only when its hot out. no problems over winter
2007 Versa SL HatchPower Package; Convienence Package; SIRIUS; Sunroof; CVT
brownbrix
Winnipeg MB
10-12-2006
damm you all have that problem i only had it happen to me twice. Scared the crap out of me but im a tech but what kind of gas are you guys putting in. Im using what the mfg told me i think the unlead regular 89 octane in canadahopefully someone will give us the right answer so we can all go to our dealer and tell them too look at this
2007 Nissan Versa SL Arctic White
GoodbyeCavalier
Versa 2007
Pasadena MD
2-8-2007
| « Re: (brownbrix) | 8:52 PM 7/10/2007 |
91 octane
differentdave
Nissa Versa 1.8 SL
Suffolk NY
6-26-2007
| « Re: (GoodbyeCavalier) | 7:11 AM 7/11/2007 |
I to am having start up problems, I have 700 miles on versa sl with intelligent key, I use regualr unleaded gas. Started yesterday. I have a remote starter, thought I started it , got to car and it wasn't running, it turned right over, paid no attention to it. Later on in day same issue. So I hit remote start as I was infront of car laast night. Sure enough it cranked for a while, failed, tried again failed and then stopped. I got in turned it over once and it started. This morning, I went directlly to car to start from inside car, and again it would not turn over, just cranked. A few tires later it started right up. VERY ODD
seize
Versa SL HB
Minneapolis MN
6-4-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (seize) | 10:40 AM 7/11/2007 |
Just to update on my trip to the dealership. It did it all the way up back from Iowa, did it at home and after work. On the Friday I had the appointment scheduled -- nothing. Worked like a charm. It's like the service guy said: It's like it knew it was going to the doctor, and the problem went away. It's done it only once since then (last week) and doesn't seem to be a huge problem anymore. I haven't noticed any common conditions that seem to cause this. But if anyone can figure this thing out, I'd really appreciate it. It seemed like I was the only one who had seen this. Now, apparently, it's a little more widespread. I hope Vice grows out of it. If anyone does it in front of a service center, let me know. I don't want my guys to think I'm crazy. Side story: I fit my girlfriend's bike in the backseat, no problem. I was quite impressed. I did ding up the paint a bit, but nothing too bad.
EdKrull
Nissan Versa SL CVT
Dallas TX
7-6-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (seize) | 11:56 AM 7/13/2007 |
OK, update on mine. I have a V with no convenience package. It starts fine in the morning, but any time after that it takes between 3 and 5 seconds to start. I took it to the dealership, and I happen to be a family friend of the service manager that I got. Anyway, he was thorough in digging around for a solution, and finally found out that this is a known issue with a limited number of the Versas, and that Nissan Tech is working on a solution. He doesn't know if it will end up in a recall to replace a part or what. Nice to know that we aren't all crazy... Anyway, if you are having this I would get to a dealership and let them add you to whatever list they are keeping of people having this problem. I suspect it is a good chunk of us (as both me and my friend who have V's are having this issue).
EdKrull
Nissan Versa SL CVT
Dallas TX
7-6-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (EdKrull) | 12:50 PM 7/16/2007 |
| Quote, originally posted by EdKrull » | | OK, update on mine. I have a V with no convenience package. It starts fine in the morning, but any time after that it takes between 3 and 5 seconds to start. I took it to the dealership, and I happen to be a family friend of the service manager that I got. Anyway, he was thorough in digging around for a solution, and finally found out that this is a known issue with a limited number of the Versas, and that Nissan Tech is working on a solution. He doesn't know if it will end up in a recall to replace a part or what. Nice to know that we aren't all crazy... Anyway, if you are having this I would get to a dealership and let them add you to whatever list they are keeping of people having this problem. I suspect it is a good chunk of us (as both me and my friend who have V's are having this issue). |
Quick Update on this... They don't have a solution yet, and the tech filled my ticket in saying that that car was working to specs (he said they don't want to start replacing parts when they don't know what the problem is). I have a complaint call in at 1800-NISSAN1 to make sure that this continues to be considered an issue. A new car should inspired confidence, not trepidation. That said, it hasn't left me stuck anywhere and I love everything else about the V. I just want to make sure that someone somewhere is looking in to a real fix for this.
Deke40
Freeport Texas
3-31-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (EdKrull) | 4:44 PM 7/16/2007 |
After a week or so of delayed starting mine is working fine again. Starts with just a short touch of the start position. Go figure. This is the second are third cycle of this in the 3 and a half months I have had it.
Modified by Deke40 at 8:19 AM 7/17/2007
michelkenny
2007 Versa SL w/ CVT + Tech Package (Canadian)
Winnipeg MB
10-27-2006
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (Deke40) | 5:26 PM 7/16/2007 |
Just to let you guys know that this happened to me twice about 3 months ago. Couldn't get the car started, waiting 5 minutes, then it started.
EdKrull
Nissan Versa SL CVT
Dallas TX
7-6-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (michelkenny) | 5:52 AM 7/17/2007 |
Deke, you live in Texas too right? I wonder if it could be the ethanol blend that most places have here. Maybe I need to be using a higher Octance or purer gasoline... Since mine also stated at 400 miles, that was just about my first fill up...
Deke40
Freeport Texas
3-31-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (EdKrull) | 8:23 AM 7/17/2007 |
| Quote, originally posted by EdKrull » | | Deke, you live in Texas too right? I wonder if it could be the ethanol blend that most places have here. Maybe I need to be using a higher Octance or purer gasoline... Since mine also stated at 400 miles, that was just about my first fill up... |
Might be but and can't understand why it cycles when the gass should be fairly consistent in quality. I guess until Nissan gets enough complaints and figures it out I am going to live with it and not pay 10 cents more a gallon hoping it will correct it. I still think my Versa is the greastest thing since sliced bread.
EdKrull
Nissan Versa SL CVT
Dallas TX
7-6-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (Deke40) | 1:10 PM 7/19/2007 |
Update - my friend who is having the same problem (5-10 seconds of key turning) took it in to antoher tech and they are going to replace her fuel pump. They are backordered, but I am going to bring mine in to get on the list as well.
GoodbyeCavalier
Versa 2007
Pasadena MD
2-8-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (EdKrull) | 1:49 PM 7/19/2007 |
taking mine in on Wed Will advise With What they tell me
EdKrull
Nissan Versa SL CVT
Dallas TX
7-6-2007
| « Re: Start-up problems at 400 miles? [Up ... (GoodbyeCavalier) | 11:00 AM 7/20/2007 |
OK, my Service Manager got me in line for a new, redesigned fuel pump. Hope it does the trick... good overall response from Nissan, love the Versa!
srellim234
2007 silver Versa SL HB w/CVT, 16,507 miles, 28.33 mpg
Rancho Cucamonga CA
7-15-2007
| « Re: Start-up problems at 400 miles? [Up ... (EdKrull) | 11:16 AM 7/20/2007 |
Can we tell when these cars were mfr'd? It would be interesting to find out if all the cars having this problem came off the assembly line together.
ThirstyRoss
Toronto Ontario
5-8-2007
| « Re: Start-up problems at 400 miles? [Up ... (srellim234) | 11:35 AM 7/20/2007 |
| Quote, originally posted by srellim234 » | | Can we tell when these cars were mfr'd? It would be interesting to find out if all the cars having this problem came off the assembly line together. |
All North American Versa's come from a plant in Mexico, as I understand it.
EdKrull
Nissan Versa SL CVT
Dallas TX
7-6-2007
| « Re: Start-up problems at 400 miles? [Up ... (ThirstyRoss) | 12:01 PM 7/20/2007 |
I don't know if Sentras are made in the same Mexico plant that all of the Versas are, but my Service Manager said they are doing this for Sentras that are having the same problem. More likely a problem with wherever the Fuel Pumps are made than at final assembly in Mexico (unless the FPs are made there)...
matt_a
Hanover PA
6-26-2007
| « Re: Start-up problems at 400 miles? [Up ... (EdKrull) | 12:37 PM 7/20/2007 |
| Quote, originally posted by EdKrull » | | I don't know if Sentras are made in the same Mexico plant that all of the Versas are, but my Service Manager said they are doing this for Sentras that are having the same problem. More likely a problem with wherever the Fuel Pumps are made than at final assembly in Mexico (unless the FPs are made there)... | I'm pretty sure I remember reading somewhere that the Versa and Sentra are made at the same factory in Mexico. I could be mistaken, but I'm pretty sure I read/heard that somewhere. I also think that those two cars share some mechanical and electrical components.
Demonspawn
2007 Sapphire Blue Versa HB SL/CVT Tech Pkg, 1998 Mustang
Frankfort KY
4-30-2007
| « Re: Start-up problems at 400 miles? [Up ... (matt_a) | 12:47 PM 7/20/2007 |
the sentra is made in tenn.
AEM CAI,Convience pkg,Tech pkg,tint
Ever Victorious
'08 Kia Spectra5, '64 Rambler American
Everett WA
8-2-2006
| « Re: Start-up problems at 400 miles? [Up ... (srellim234) | 2:22 PM 7/20/2007 |
Versa Hatchbacks are mostly made at a plant in Aguascalientes, Mexico. Originally, Nissan had decided to make 40% of all Versas into hatchbacks, and 60% sedans. When they saw the actual sales numbers, they reversed that, making 60% hatchbacks and 40% sedans. Aguascalientes is supposedly not a large enough plant to make these numbers of hatchbacks, so supposedly part of the 2nd Mexico plant, where the Sedans are made (I forget the name of it) ALSO makes hatchbacks. But there are 2 different Mexico plants that the Versas are made at. Most of us here will have had ours built at Aguascalientes.
Mileage as of last fillup: 29265 Economy (Lifetime/Worst/Best): 29.79/26.12/34.72 MPG Buh-bye Versa. Too bad you broke so often.| Quote, originally posted by KimberKenobi » | Jesus on Toast.
jacksan1
St. Paul MN
9-17-2006
| « Re: Start-up problems at 400 miles? [Up ... (Ever Victorious) | 1:55 PM 7/30/2007 |
The other assembly plant is in Cuernavaca.
PB
Ontario
6-28-2007
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (EdKrull) | 4:42 PM 7/30/2007 |
I am hearing nothing about the problem in canada here,My car seems ok,Could it be bad gas at some stations where you are,Maybe even some moisture causing the problem.Try changing brands or go to another station and try that for awhile.
2007 Nissan Versa S Auto,Value package Blueberry/Metallic
brownbrix
Winnipeg MB
10-12-2006
| « Re: Start-up problems at 400 miles? [Update: Fuel Pressure prob?] (PB) | 10:41 PM 7/30/2007 |
| Quote, originally posted by PB » | | I am hearing nothing about the problem in canada here,My car seems ok,Could it be bad gas at some stations where you are,Maybe even some moisture causing the problem.Try changing brands or go to another station and try that for awhile. |
i live in winnipeg. and now i had my 4 time having this done to me. Brought it in once all ready they say they have no idea. I think it has to do with the fuel line or fuel pump which has been posted on another thread and in this one too..Damm nissan needs to get this fix what happens when it wont start at all dun dun
| First 1 2 3 > Last |
