centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Thu May 11, 2017 12:41 pm
Well, with the CVT, I don't think you have a cable. I think it's merely a series of switches (buttons) that go to wires that tell the CVT what to do. It is described thoroughly in the FSM that I gave you a link to, starting at page TM-105. Please try and use the FSM. The solution to your issue is 99% likely to be in there.
While you're at it, do you have any check engine light codes? Can you get a scanner and check for those please? There might be a clue as to what's not working if you have some codes.
Also, your description could be elaborated a bit. There's more diagnoses in the FSM for the CVT and it has to do with what does and doesn't work. You don't state if you can put the selector in P, so I'm stuck thinking your car only goes into R and N (per your words), so it won't start or run, and you can't drive or anything. But if you can drive it be sure and tell us. Maybe it drives in reverse only? I can't tell. Can you put it in P? Can you start the car while in P? Symptom diagnoses starts on page TM-196
