2007 M35 sport with Bose surround
gmoney35s
Car: 2007 M35S
I'm in the middle of this install (LOC to amp and sub) the LOC is the Audiocontol LC2i my question is which wire do I tap into for the speaker I already ran my remote wire and power wire and a ground wire so where do I run the speaker wires to please help and ASAP so I can get my ride together again on a positive note I did get the grill plastidipped big thanks to gqm45
TXT
Car: 2006 M45 Sport
See if this post will help you out.....Third post down
2007-m35-subwoofer-installation-t529737.html
gmoney35s
Car: 2007 M35S
Thanks I had this one out yesterday in the middle of the install but none of the pics came up etc I guess my phone was being ignorant or something but it's all up and running so ill finish it up today not gonna be anything extravagant yet I just need some more bass in my trunk lol
06M4.5
Car: 2006 M45
Audiocontol LC2i doesn't need a remote wire.
If your running a new sub you can get the wires from the oem sub.
gmoney35s
Car: 2007 M35S
But if the amp (aftermarket) is constant hot doesn't that need a remote wire ?? Now I'm confused lol I'm pulling the speaker signal from the wire that go into the sub just like the posting in this thread that was given to me I know that the hook up said u can pull from the factory remote wire (brown) but both both LOC and amp have a remote wire
06M4.5
Car: 2006 M45
Audiocontol LC2i doesn't need a remote wire to turn on. Just run a remote from the LC2i to the amp.
Everytime you turn on the radio the LC2i will turn on by it's self thru the sub wires from the oem sub :yesnod
gmoney35s
Car: 2007 M35S
Ok so basically run a power wire to battery run ground to car and take that brown remote wire and run it to the aftermarket amp and run a jumper from aftermarket amp To LOC am I using the remote out or in on the LC2
06M4.5
Car: 2006 M45
Call me you sound confused and I'm a slow typer :frown:
201-889-3089
PM sent
06M4.5
Car: 2006 M45
Look on the left side of the cool/heat knobs. You can see the the bass knob
gmoney35s
Car: 2007 M35S
Thanks i like that spot for the remote that's where ima set mine ill get out the dremel
06M4.5
Car: 2006 M45
Robert & I have it the same for now
and I used a drill to make the hole in order to run the wire :biggrin:
gmoney35s
Car: 2007 M35S
Did u pull the controller off the LOC or the amp
06M4.5
Car: 2006 M45
The bass knob is connected to the LC2i
