diesel5599 »
https://forums.nicoclub.com/diesel5599-u61456.html
Tue Apr 03, 2007 12:54 pm
Nice setup, I've never had a custom setup before. I change cars every year or two so I go with a generic sub box and mount the amp on the box so that I can easily move it between cars. Only problem is, each time I get a new car I want a better system, so it usually ends up gathering dust. I've got 3 complete systems now gathering dust in the corner.
I'm not sure about the firewall entry, noticed yours is an '05 coupe, under the hood of my '07 sedan, it looks like I couldn't get a needle and thread through the "space" around the master cylinder. The steering boot / master cylinder is always the first place I check, but this time it does not look possible.
Also, my battery is located on the passenger side, and I'm a bit leery of running amp wiring from one side of a hot engine bay to the other. All of my past cars had the battery conveniently located on the drivers side right in front of the firewall pass through.
Its looking like this may be the first car where I run the wires outside, to the back, and back in around the rear struts. Under the back seat there is a removable cover that I think I can use to get back in, but I'd much rather run the cable inside the car.
As far as power goes, I've already backed down from getting 2 Kicker S10X's and 2 KICKER KX 2500.1's to power them. The car would probably cut off when the bass hit. So I've lowered my sights to 1 KICKER KX 2500.1 and probably 1 SoloX 12". The amp should hold with a Optima Yellow Top and 10F cap. I ran a setup similar to this in my previous car and it had a smaller amp.
