I would like to do a power balance test. I have Torque Pro and a Bluetooth connector which will provide only read access. I downloaded and installed the Advanced EX Nissan plugin (
https://play.google.com/store/apps/deta ... n_US&gl=US ) which includes many Nissan models, including the Maxima with the VQ35DE engine, but not the Pathfinder with that engine. I am hesitant to try software written for a different model, as it could cause damage.
Back in 2010, when I bought the car, I bought the blaZt software and adapter cable (RS232). I used it for years to troubleshoot various issues and it was very effective. But they went out of business years ago and off the grid, at least by that name. Does anyone know of a modern equivalent that works with the 'standard' Bluetooth adapters?
It is looking more like a fuel injector issue. Here's a very informative post about stuck injectors:
gas-coming-out-of-tailpipe-t435389.html
But I'm not seeing a vapor trail yet. And it is possible that the dripping from the tailpipe is condensed water mixed with unburned fuel. The injectors are hidden under the manifold collectors; I cannot even get to the connectors.
Should I order a set of after-market injectors ($65 for a set of 6) or get the OEM? I found a set of remanufactured Bosh OEM on ebay for $60.
I will also need a gasket set for the intake manifold collectors. Should I plan to replace the leaking valve cover gaskets while I am in there?
Is there a good 'how to' instructions for this job?
What is the best way to relieve the fuel pressure before disassembly? remove fuel pump fuses and run the car until it stalls? Or is it better to remove the relay?
