odie wrote:The sound is excellent. Just starting the car makes me smile.The fit was "eh".... we did as much as I could to make it look symmetrical.
I'll probably take some more head on shots but here's some pics from install.Yes, I had the car jacked up only on one side due to the garage space being so cramped.
Btw, had to grind off two bolts on the mid pipe. Otherwise, pretty smooth install.
Yeah, I can see that even your tips are at different heights and crooked on the left side. You should be able to loosen the flange bolts on the left side and twist it clockwise some.... if your not already as far as it will go.
It seems those center nuts were pretty damn stubborn. I even saturated the bolt threads and nuts with WD-40 for a few hours before trying to get them loose.I didn't want to damage the welded on bolt threads or have to cut them off. I muscled one of the nuts off, but I had to used an air chisel to loosen the other one. The air chisel worked great. Loosened the nut that was rounded off and was easily back off from there. It is always nice to have the right tools for a problematic job. I have to admit, I have a fair amount of tools, but I could use a lot more of them.I also learned another thing, those drive up ramps didn't help all that much. I had to jack up the front of the car higher than the rear to get those center bolts off. I guess I need to invest in another quality hydraulic floor jack and some good heavy duty jack stands.
I still do not regret doing this job myself. I enjoy doing these types of upgrades. It's not a real easy job only due to the fact an individual will have a difficult time getting the center nuts off. Other than that, it went pretty smoothly.
They do need to spend more time on the fit and finish of the product. The exhaust don't look so great if it doesn't sit symetrical.They need to address their inconsistancies with their jig they are using to produce these kits.This is the only kit that I have ever installed that I could not adjust out perfectly.I still give them props for the sound tone of the exhaust note.The sound clips all given do not replicate the actual depth of the exhaust note this kit will emit. It is louder than you might think. What really counts is, my wife likes the sound!
J
