Right? Lol.steve_c wrote:welcome to the forum...
Where have you been all this time!
Thanks EdBwoy...EdBwoy wrote:1. I have a question on the type of coolant you are using. Is it concentrate or 50/50?steve_c wrote:welcome to the forum...
2. Have you checked the FSM? There should/might be another thermostat in the back of the engine. It is usually located in the valley and might be referred to as a proportioning valve.
3. On blockage and restriction, can you force feed water into the inlets for both heat exchangers (front rad and heater core) and see if water comes out of the other end?
I don't think the heater core will be it though, because that is a passive sytem that can be bypassed, and its issues shouldn't make your engine overheat. Also, just check it by turning the heat on.
Engine off might be the issue here as the pump isn't turning, thus just acting as a closed valve.3. So what I JUST did was run a hose into the top of the radiator neck, no flow out of the upper hose that's connected to the heater core. Ran same hose into the upper hose, no flow out of the upper radiator neck. This was done with engine off.
Ahhh Yes!EdBwoy wrote:Right? Lol.steve_c wrote:welcome to the forum...
We do seem welcome members fighting fires right out of the gate, but neverthelesss we love to welcome people. Welcome aboard!
I was hoping I wasn't THAT stupid, but apparently I am....lol. I really thought about that AFTER I posted what I did.EdBwoy wrote: Engine off might be the issue here as the pump isn't turning, thus just acting as a closed valve.
Disconnect both hoses that come from the radiator and test it like that.
Any idea if some form of radiator stop leak has been used in that vehicle?
I don't think installed the T-stat incorrectly. I did check the new one before installing, via the boiling water method, to see if it would open @ before 212*. Then tested it again vs the old one. Both opened at the same time.steve_c wrote:Well,
Sounds like you are pretty competent in diagnosing & wrenching.
Any chance you installed the T-stat incorrectly, or that it (the new T-stat) may be defective?
When you say fans are OK, that is to say you actually see the overheat condition taking place with the fans running, having no cool down effect?
Is your A/C condenser & radiator free from external debris blocking air flow?
If it were my car, I would remove the T-Stat, leave it out & reassemble to see if you get flow action without it. Also, with burping, putting the car on an incline (nose up) while using the burping funnel helps. I have had to bleed off some air at the coolant service port located on the R/S of the engine near the firewall (I think you said you did that). Use precautions when bleeding at that port.
With your VIN in hand, try calling Infiniti USA (or a dealer) to see if your VIN was part of the fan controller recall.
I have an early build VIN (car built 6/05) and my fan controller started operating erratically after about 4 years of service (summer of 2009 I think it started to intermittently overheat).
You are right about this. I dealt with a pathfinder engine and didn't know the sedans got the VQ35 without the secondary valve. It only made sense to me to have it, as it did to whoever designed the M45 V8 apparently.I have checked the FSM. However, I did not see mention of a second t-stat or proportioning valve.
Please, show me the ways! lolsteve_c wrote:Ahhh Yes!EdBwoy wrote: Right? Lol.
But this one looks promising....maybe he will decide to join us and learn the ways of the force.....
The radiator flows. Feeding water into the radiator thru the top, flows it out of the bottom. Now, I wouldn't know how to isolate the radiator from the rest of system to check for flow through the rest of system. I'm going to remove the T-stat now though...EdBwoy wrote:What happens if you feed something through the upper hose into the radiator - will it drain at the bottom?
Also, while doing the running tests and purging it, have you squeezed the bottom radiator hose until you see water out of the top radiator hose?
What I'm trying to see is:
- Is the radiator actually full of liquid?
- And once you isolate the rad from the rest of the system, is it actually allowing fluid through?
I'll get to this shortly.EdBwoy wrote:Fugaman, could you post some pics of your engine bay showing the layout of the hoses, radiator & inlet pipe. I got mixed up looking it up online.
Here are some ways to upload pics:
1. using IMGUR
2. using PHOTOBUCKET
3. using TINYPIC
steve_c wrote:Well,
Any chance you installed the T-stat incorrectly, or that it (the new T-stat) may be defective?.......If it were my car, I would remove the T-Stat, leave it out & reassemble to see if you get flow action without it. Also, with burping, putting the car on an incline (nose up) while using the burping funnel helps. I have had to bleed off some air at the coolant service port located on the R/S of the engine near the firewall (I think you said you did that). Use precautions when bleeding at that port.
Fantastic!Fugaman wrote:OK, so I removed the t-stat from the housing, reinstalled and now I have flow. So that tells me that the t-stat isn't opening/closing properly. I just don't know why. I call myself doing the boiling pot water test before installation to see.
What are the dangers of running the car without a t-stat for an extended period of time?
Well, at this point, I'm wanting to trade the car in as I need something a bit more reliable.steve_c wrote:
Fantastic!
I think for the summer you will be OK without a T-stat. Winter is another story. T-Stat lets coolant & oil warm up quickly to operating temps so impurities can start boil off in oil & OBD can go into closed loop quickly, thus controlling emissions. You want the oil to be at engine operating temps to reduce engine wear.
I'm pretty sure, as Autozone sells the entire unit, complete with housing and all.steve_c wrote:Go for a Nissan OEM T-stat next time around. Are you 100% sure you did not install the stat upside down?
I mentioned the T-stat a few times in my response to the OP above. Many aftermarket T-stats are generic and may not be specifically engineered for the application at hand.steve_c wrote:steve_c wrote:Well,
Any chance you installed the T-stat incorrectly, or that it (the new T-stat) may be defective?.......If it were my car, I would remove the T-Stat, leave it out & reassemble to see if you get flow action without it. Also, with burping, putting the car on an incline (nose up) while using the burping funnel helps. I have had to bleed off some air at the coolant service port located on the R/S of the engine near the firewall (I think you said you did that). Use precautions when bleeding at that port.Fantastic!Fugaman wrote:OK, so I removed the t-stat from the housing, reinstalled and now I have flow. So that tells me that the t-stat isn't opening/closing properly. I just don't know why. I call myself doing the boiling pot water test before installation to see.
The 2 T-stats that I had prior to my current one were AutoZoo T-stats. I don't think the 1st one was defective, but the 2nd one definitely was. Looking at them both, The OEM Nissan one is definitely of a better design & build.steve_c wrote:
I am glad we were able to assist the OP. Was your original T-stat defective?
