Ok , so hear are the details.....just randomly I leave a friends house crank the M and I get Service engine soon light , SLip and VDC OFF light , I wasn't to worried as ive had this issue before and I replaced the Crank sensor near the oil pan and it fixed it. SO I cut the car off and restarted just to see , it kinda hard started but started and I drove it home , no issues driving home. So when I get home , I decide to disconnect the negative battery cable just to see if that will reset the codes and maybe they go away.....so here is the crazy part to me. I disconnect the battery cable and leave it for about 30 minutes and then connect it back and now the car wont do anything ?? Not anything ...no noises of a starter , wont try to crank ....just dead. I press the button and nothing happens at all. Ive tried putting the key fob in the side port and still nothing.
However , I do have power for headlights to come on , brake lights and interior lights come on. No lights on dash , even the push button start is not lit. Also the security red light on dash is blinking. Another strange thing is my key fob doesn't do anything now either??
Things i've tried so far , I cleaned the negative cable and reseat it several times , checked the battery with multi meter ( checked good) and i've even tried to jump it off and still nothing. Checked fuses and found no problems there.
I have no idea what I could have done ? Any ideas ? or it looks like i'm gonna have to get it towed to the shop I use and hope they can fix it.
Thanks for any help you can provide , ive done a lot of searching already on here and haven't found anything like my issue.
