I would expect you to get a code thrown if there was a problem with the MAF sensor, but I suppose not necessarily. Is the Check Engine light on? Regardless, there's a troubleshooting procedure for P0100 in the EC - Engine Control System that you can follow to help determine if the MAF sensor is bad.
I also saw that someone else had a similar problem with their CAI because it wasn't getting enough air. I don't think that's the case here, but you'll probably want to remove your airbox resonator anyway:
my-intake-mod-t444483.html
