I looked at the Infiniti parts diagram and it doesn't show the spark plug tube gaskets. So I assume they are of the non-serviceable model.AZhitman wrote: ↑Tue Jan 28, 2020 9:24 pmWelcome aboard... You have a VQ35DE engine, same as a Pathfinder.
Here's your gaskets: https://www.amazon.com/Fel-Pro-VS50608R ... B000Q0U7Q6
...and your spark plug tube seals: https://www.amazon.com/Nissan-13276-31U ... B00KWGCMJ4
I saw some discussion that the plug tube seals aren't serviceable, but I can't imagine why they wouldn't be (and there's a part number).
I might need the valve rocker cover, not just the gasket. Nissan has different part numbers from the Infiniti parts, so how can I know if I'm ordering a compatible valve cover?AZhitman wrote: ↑Tue Jan 28, 2020 9:26 pmYou can also go thru these guys: https://www.nissanpartsdeal.com/oem-nis ... l=&Filter=()
Nothing came up for a valve cover for a 2003 Pathfinder.AZhitman wrote: ↑Tue Jan 28, 2020 9:26 pmYou can also go thru these guys: https://www.nissanpartsdeal.com/oem-nis ... l=&Filter=()
Definitely gonna do the threadlocker on the powervalve screws.AZhitman wrote: ↑Tue Jan 28, 2020 9:44 pmNope, different models use different rocker covers.
Apparently they're not serviceable - My mistake. Here's some more discussion that may be helpful: 2002-valve-cover-gasket-replacement-t597524.html
That valve cover is for the Infiniti QX4. Same part number. That price is within a few dollars ($199. vs $207.) of the discount price on the Infiniti website. I'd like to find and aftermaket valve cover at hopefully a better price. That's painful price to pay, just because the spark plug tube gaskets are not serviceable.
Here's a short video that shows closeup and detailed *why* they are not serviceable.AZhitman wrote: ↑Tue Jan 28, 2020 10:08 pmYep, I caught that. Nothing aftermarket that I've seen, except for some janky Alibaba shat.
Honestly, I'd take them apart and inspect, and determine why they're supposedly not serviceable (when there's a part # for the tube seals).
Then again, I take stuff apart for fun (and to help people here fix their stuff).![]()
