2003 Nissan X-Trail
topmeasure
Car: 2003 Nissan X-Trail
I have a 2003 Nissan X-Trail. The transmission lever works fine, moves from park to neutral to drive, etc.., but the transmission will not engage, it stays in park. Any idea what could be causing this? Thanks.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to NICO!
Your X-Trail shares much in common with the Rogue, so I've moved your thread here.
There's a thread on the Shifter Stuck In PARK problem, but it sounds more like your shift linkage is damaged/broken.
frijolito
Car: Rogue (Xtrail) 2020 Advance
I had this in my pathfinder, the bushing that connects the shifter to the linkage underneath maybe broke. You can fix it temporarily using a similar method in that thread, just stick a screwdriver into the selector beneath and you should be able to change gear enough to move your car and get it fixed properly. I ended up getting a poly bush made up so it wouldn't happen again...
topmeasure
Thank you guys. Love the site. :dblthumb:
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
the cable and its components might be broken.
topmeasure
I've checked and the cable is broken right at the end where it connects to the transmission. Trying to find a used one but no luck yet. Thanks for all the comments.
topmeasure
Hey guys. Is there only one cable running from the shifter to the transmission? I could only see one. Thanks.
Rogue One
2022 Honda Pilot SE
topmeasure
Hi guys. Could someone send me a picture of the shifter cable for a 2003 nissan x-trail for an automatic gear box and would you guys know the diameter of said cable. Many thanks.
Return to “Rogue Forum”
