caug1 wrote:also i think new tires i will get will be falken azenis rt 615. you should read reviews on them. they are very good and cheep. they dont come in right size., but did talk to the guy from discounttiredirect.com i can you 245.40.18 wider tire less sidewall bigger contact patch. he did corculation tald me speed will be of by half of the mile, becouse tire smoller by 1/4 of an inch.
Since the rolling rev/mile of this tire is 803, the actual speed will be 58.7 mph at a displayed 60 mph, compared to the stock 235/45-18 tires. I do agree that this is relatively minor!
More importantly though, the minimum rim width (for this 245/40-18 tire size) is 8.0 inches because of the lower aspect ratio tire. Unfortunately, the stock 2003 M45 rim is 7.5" wide. While this is a minor difference, and the tire should fit this rim without being unsafe, keep in mind that the edges of the tire will "lift" a bit and the tread width will effectively go down a bit. So, the point of having a wide tire will be lost.
My point being that a 245/45-18 size is a better fit for this OEM rim, and unfortunately, the Azenis RT-615 is not available in that size!
Also, the Azenis RT-615 is a dated tire. It is a somewhat dated design and the material is also not up to par compared to today's tires (UTQG rating is 200 A A) and there are definitely better tires available now (albeit perhaps not as inexpensive).
If you want to stick with Falken, their FK-451 and FK-452 in a 245/45-18 will probably give you better results on a 2003/2004 M45. I do not have any personal experience with these, though ... I have only used their Ziex 512 (now called the ZE-512) and did like it on my 1995 Q45. That tire is not available in the right size for an M45, though.
If you want more info, please check out my tire spreadsheet in the Basic Spec sticky thread.
Z
