audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Sun Sep 09, 2007 3:59 am
If the car has been to an Infiniti dealership recently, then all recalls have probably been performed. You can contact you local Infiniti dealership service department and have them run your VIN to see if there are any that have not been performed. Of note, the only 2003 recall listed that could cause "limp home mode" is ID# 03V455000
Current recalls for 2003 G35:
Recall ID# 03V200000 - SERVICE BRAKES, HYDRAULIC:SWITCHES:BRAKE LIGHT Recall Date: JUN 02, 2003 Model Affected: 2003 INFINITI G35 Summary: ON CERTAIN SEDAN AND COUPE MODEL VEHICLES, THE BRAKE STOP LAMP SWITCH MAY MALFUNCTION. Consequence: IF THIS OCCURS, THE BRAKE LAMPS WILL NOT ILLUMINATE WHEN THE BRAKE IS APPLIED, WHICH COULD RESULT IN A CRASH WITHOUT WARNING. Remedy: DEALERS WILL REPLACE THE BRAKE LAMP SWITCH. OWNER NOTIFICATION BEGAN ON JUNE 23, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT INFINITI AT 1-800-662-6200. Potential Units Affected: 60000 Notes: NISSAN NORTH AMERICA, INC. R3011
Recall ID# 06E060000 - EXTERIOR LIGHTING Recall Date: JUN 29, 2006 Model Affected: 2003 INFINITI G35 Summary: CERTAIN AAI MOTORSPORTS COMBINATION LAMPS SOLD AS REPLACEMENT LAMPS FOR USE ON THE ABOVE LIST PASSENGER VEHICLES. COMBINATION LAMPS NOT EQUIPPED WITH AMBER SIDE REFLECTORS FAIL TO CONFORM WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, ?LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.? Consequence: LACK OF AMBER SIDE REFLECTORS IN THE LAMPS WILL DECREASE LIGHTING VISIBILITY TO OTHER DRIVERS AND MAY POSSIBLY RESULT IN A VEHICLE CRASH Remedy: AAI MOTORSPORTS WILL NOTIFY OWNERS AND REPLACE THE LAMPS FREE OF CHARGE. THE RECALL BEGAN ON AUGUST 1, 2006. OWNERS MAY CONTACT AAI MOTORSPORTS AT 909-923-9188. Potential Units Affected: 87745 ----------------------------------------------------------
Recall ID# 05V555000 - FUEL SYSTEM, GASOLINE Recall Date: DEC 13, 2005 Model Affected: 2003 INFINITI G35 Summary: ON CERTAIN PASSENGER AND SPORT UTILITY VEHICLES, THE FUEL FILLER HOSE MAY CRACK AND RESULT IN FUEL LEAKAGE FROM THE HOSE WHILE REFUELING. Consequence: FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE. Remedy: DEALERS WILL REPLACE THE FUEL FILLER HOSE. RECALL BEGAN ON FEBRUARY 27, 2006, FOR NISSAN OWNERS, AND ON MARCH 13, 2006, FOR INFINITI OWNERS. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261 OR INFINITI AT 1-800-662-6200. Potential Units Affected: 192659 ----------------------------------------------------
Recall ID# 03V455000 - ENGINE AND ENGINE COOLING Recall Date: NOV 17, 2003 Model Affected: 2003 INFINITI G35 Summary: ON CERTAIN PASSENGER VEHICLES, THE CIRCUIT BOARD FOR THE CRANK POSITION SENSOR OR CAM POSITION SENSOR MAY HAVE AN IMPROPER SOLDER JOINT DUE TO SOLDER DEFORMATION CAUSED BY HEAT STRESS ACCELERATED BY THE EXISTENCE OF FLUX RESIDUE DURING THE SOLDERING PROCESS. Consequence: THIS COULD CAUSE THE "SERVICE ENGINE SOON" WARNING LIGHT TO COME ON, CREATE A NO START CONDITION, CAUSE REDUCED ENGINE POWER, OR CAUSE THE ENGINE TO STOP RUNNING WITHOUT WARNING DURING VEHICLE OPERATION, WHICH COULD RESULT IN A CRASH. Remedy: DEALERS WILL REPLACE THE CRANK POSITION SENSORS. CAMSHAFT POSITION SENSOR(S), AND IN SOME CASES, THE VARIABLE TIMING CONTROL SENSOR(S). VEHICLES INVOLVED IN A PREVIOUS RECALL CAMPAIGN, 01V357, ARE ALSO INCLUDED IN THIS NEW CAMPAIGN. THE REPLACEMENT SENSORS USED IN THAT CAMPAIGN ARE ALSO AFFECTED. OWNER NOTIFICATION BEGAN ON DECEMBER 22, 2003. OWNERS SHOULD CONTACT NISSAN AT 1-800-647-7261 OR INFINITI AT 1-800-662-6200. Potential Units Affected: 630000 ----------------------------------------------------
Recall ID# 02V331000 - EXTERIOR LIGHTING:HEADLIGHTS Recall Date: DEC 12, 2002 Model Affected: 2003 INFINITI G35 Summary: CERTAIN SEDANS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, ?LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.? IN THE ASSEMBLY OF THE HEADLAMPS, IT IS NECESSARY TO HAVE A MEANS TO ADJUST THE HEADLAMPS. TAMPERPROOF CAPS TO PREVENT HORIZONTAL ADJUSTMENT OF THE HEADLAMPS ARE THEN INSTALLED. SOME OF THESE VEHICLES ARE MISSING THE TAMPERPROOF CAPS. Consequence: Remedy: DEALERS WILL INSTALL THE MISSING TAMPERPROOF CAPS ON THE HEADLAMP ASSEMBLIES. OWNER NOTIFICATION BEGAN JANUARY 20, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT INFINITI AT 1-800-662-6200. Potential Units Affected: 36000 ----------------------------------------------
Recall ID# 02V245000 - FUEL SYSTEM, GASOLINE:DELIVERY:HOSES, LINES/PIPING, AND FITTINGS Recall Date: SEP 12, 2002 Model Affected: 2003 INFINITI G35 Summary: ON CERTAIN PASSENGER VEHICLES, THE FUEL HOSE CONNECTION FOR THE OUTLET OF THE FUEL PUMP WHICH IS LOCATED AT THE TOP OF THE FUEL TANK MAY NOT HAVE BEEN PROPERLY ATTACHED WHEN THE VEHICLE WAS ASSEMBLED AND COULD COME LOOSE WHILE DRIVING OR WHEN STARTING THE ENGINE. Consequence: IF THE CONNECTION COMES LOOSE WHILE DRIVING, THE ENGINE WILL STOP RUNNING DUE TO LACK OF FUEL, INCREASING THE RISK OF A CRASH. ALSO, IF THE CONNECTION COMES LOOSE WHILE DRIVING OR ATTEMPTING TO START OR RESTART THE ENGINE, SOME FUEL WILL DISCHARGE FROM THE FUEL PUMP. IF THIS SHOULD OCCUR IN THE PRESENCE OF AN EXTERNAL IGNITION SOURCE, A FIRE COULD RESULT. Remedy: DEALERS WILL INSPECT AND, IF NECESSARY, PROPERLY ATTACH THE FUEL HOSE TO THE FUEL PUMP. OWNER NOTIFICATION IS EXPECTED TO BEGIN OCTOBER 7, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT INFINITI AT 1-800-662-6200.
