2003 FX 45 Hi Pitch Squeal when turning right or backing up only [SOLVED]
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
ndgo88
Car: 2003 FX45
Good Afternoon!
Need advice??
I have a 2003 Infiniti FX 45
I get a high pitched squeal when turning right or backing up. When turning right I get it when not braking? Any ideas what this could be?
Thanks!!
Reason: updated title
EdBwoy
Any idea where the noise is coming from - front/back, right/left?
And what is the condition of your brakes?
Let's keep an eye on this thread, something might pan out of it. Otherwise, try some of the troubleshooting recommended in it and let us know what you find.
brakes-squealing-03-m45-t613541.html
However, if you can record a video of it, that would helpful too.
ndgo88
Car: 2003 FX45
Just a FYI-
The issue turned out to be a brake dust cover rubbing against the rotor.
EdBwoy
Thank you for the update
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
