2003 350z have to manually raise the window
MJW
Car: Nissan Z350
Hi I have a Nissan 350Z from 2003 the window drops when door opens but does not go back up until you manually raise it with the window switch. Do you know what part I need to fix this I have managed to find a window regulator motor ? would it be that part ?. Its the same as most people I have found once the window has gone to far its a dreadful job to get it back up
Thanks Jane
Reason: Revised title
frapjap
'07 Subaru Legacy
Welcome to NICO!
Sounds like a window regulator, possibly the motor failing. Unfortunately, you can't really tell until you start replacing a part or two.
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
Window motors going out in the early 350Zs is a fairly common issue (sadly).
Here's your best solution
Welcome to NICO! :badger
