2002 Q45 Tires with uneven wear
ahmed_wasim
Car: 95 Q45
I went for tire balancing and rotation and Infiniti tech told me that one of my wheels has a crack in it. I told him to use the full size spare in the trunk and put cracked wheel in the trunk. He just moved the wheel with tire from the trunk and installed it on the rear driver side. This tire has more tread than the other one (both are michellon mx4). Does it effect handling and comfort?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Sure, but how much more we don't know. Tread depth guages are cheap. Should be in every car.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I dont think that it will cause that much of an issue.
ahmed_wasim
Car: 95 Q45
I bought the car recently (about a month). The crack might have been there before. I once went over a huge bump on a freeway while driving in MI.
ahmed_wasim
Car: 95 Q45
I have the same tire put on the new wheel so both even now.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
That's probably a good move because while traction control will hide many things, a tire with 4/32nds of tread vs. 10/32nds will behave quite differently in the rain and under braking.
szh
Car: 2018 Tesla Model 3.
maxnix wrote:That's probably a good move because while traction control will hide many things, a tire with 4/32nds of tread vs. 10/32nds will behave quite differently in the rain and under braking.
Yes!
Check this thread zerothread/211702 out for some information about what happens in wet weather ...
Z
