Nope...no Service Engine light. The fuel filter could probably be changed, not sure how old it is...just bought the car about months ago. There ar 97,000 miles on it.Towncivilian wrote:The "SERVICE ENGINE SOON" light isn't lit? Is your fuel filter recent? How about spark plugs? How many miles are on this QX4?
Thanks so much for the help...and the manual!!Towncivilian wrote:Yeah, go ahead and replace the fuel filter - there's a guide here.
The spark plugs have a 105k mile change interval, so it might be prudent to change them now. Be sure to use the OEM specified NGK FR5AP-10 plugs.
If you haven't yet, download a copy of the factory service manual here. To save a copy of the FSM, right click -> Save As on every PDF, save them into a single folder, then use fwd.pdf to navigate.
Thanks for the advice...I did some searching, and I found that a bad knock sensor shouldnt be shuting the car off (dies) when in gear. I did replace the dizzy cap and rotor as well...no change.Towncivilian wrote:What octane fuel do you run? The only code was P0325 knock sensor? Usually when the KS code is thrown it just signifies that knock is detected.
Try cleaning the throttle body and idle air control valve (guide here). Check the hoses for the PCV valve and replace the PCV valve itself (guide here).
Could this be an issue with the TPS?Towncivilian wrote:OK, that's fine, continue using 87 octane only. Anything higher will likely result in reduced performance and mileage.
OK...what is supposed to happen?Towncivilian wrote:A MAF sensor can go bad on any car. Put it in drive and disconnect the MAF sensor, see what happens.
Thanks so much for ALL the help with this.Towncivilian wrote:I've already explained the P0325 code in one of my previous replies. Your P0325 code is a side effect of your stalling issue.
The PCV is a $13 part at the dealer, change it out (I linked to its location above). If you can provide your VIN, I'll give you the exact part number.
MAF sensor is a possible culprit, but it would usually throw a code.
Loosen and retighten these ground screws:
To knock loose any carbon deposits in the EGR valve, tap it lightly with a hammer at idle and rev up a bit for a short period of time.
Thanks...but would this cause the engine to knock and stall?Towncivilian wrote:It might be the engine coolant temperature sensor that's faulty. This would usually result in a code, but I guess it's possible for the sensor to get lazy. You can see EC-178 for a diagnostic procedure. If you can provide your VIN, I can provide you with an exact OEM part number should you require a replacement. The part should be relatively cheap, around $25-35 at your local dealer.
Make sure your coolant level is correct in the overflow bottle and is up to the top of the neck in the radiator (check when it's fully cold, obviously). Inspect your radiator cap while it's off according to this TSB.
Huh...Ok. Thanks a lot! I'll report back.Towncivilian wrote:Yeah, it's possible. If the ECU thinks the coolant is cold when it's actually hot, that can cause such problems.
Boy...I really wish someone told me that before I replaced the fuel filter!!!Towncivilian wrote:I hope you removed the spare tire when you replaced the fuel filter, otherwise you really gave yourself some extra work.
I'm here to help.I hope we can solve your problem soon!
