Towncivilian wrote:Your engine does not control idle via ECM. Try to follow the service procedure as best you can on
EC-42 to check ignition timing, idle speed, and idle mixture ratio.
The crankshaft position sensor is a possibility, I've read of instances similar to yours where replacing the CKPS fixes things. Luckily they are easy to change out if all else fails and not terribly expensive.
I'll try to replace the Crankshaft position sensor tomorrow and report back.
I dont have any code readers to perform the service procedures you mention, nor have a timing light...that kind of stuff is a little over my head.
I'll report back about the Crankshaft postion sensor tomorrow.
It does mention about the IACV in those procedures, and to replace if necessary. I am not sure what you mean by "Your engine does not control idle via ECM". If the IACV goes bad, does that not make the ECM go bad as well?
I really dont know much about this engine at all...just relaying what I have read.
Thanks again for ALL the help!
