M45Caliber »
https://forums.nicoclub.com/m45caliber-u98401.html
Tue Apr 14, 2009 2:49 pm
if the only difference being discussed is that of octane, only performance at the high end of the spectrum, or under load, should be affected. The car (all new cars) compensate for octane (or lack thereof) and adjust the timing accordingly. So, under full throttle or travelling up an incline, you would notice a slight decrease in total torque and horsepower, thus, performance.
In day to day driving it should be imperceptable. Your fuel mileage is controlled by a computerized air/fuel ratio and octane really doesn't impact that, so no mileage differential should be detectable. However, most Tier 1 premium fuels have more additives and that might be beneficial in the long run for your intake, injectors, valves, piston crowns, etc.
If you are going to measure any difference in fuel mileage, you will need to perform a closed loop test with the exact climatic and driving conditons, using the same driver and technique. Furthermore, the driver can NOT know what fuel is being tested each time, so as not to impact the technique utilized. Way too many variables for us ere mortals to control, but you could use regular for a month, then premium for a month and see -- assuming you drive the same exact routes and speeds both months, which is still all but impossible to do.
You won't hurt the car using 87 octane, but Infiniti recommends (M45 is what this post was about originally) premium for a reason. At $0.25/gal more, and figuring 12,000 miles a year at 18 mpg, you will spend about $167 MORE annually (or $14/month) for premium over regular.
You just bought a $45,000 + car -- so you decide if it's worth it. Do you extend your oil changes out to 7,000 miles to save money? Why not? Think it through and do what you feel is best for your situation. If you are leasing and don't plan to keep the vehicle past the 36 month (or whatever) term, then regular will suffice and the next owner can deal with any issues that might arise.
From the Web - Octane Myths• High octane gasoline improves mileage.In general, if your car is designed to run on 87 octane gasoline, high octane gasoline will not improve mileage. If switching to high octane gasoline does improve mileage, you might find that your engine, or its control systems, need repair.• High octane gasoline gives quicker starting.No, it doesn’t.• High octane gasoline increases power.If your car is designed to run on 87 octane gasoline, you shouldn’t notice any more power on high octane gasoline. Again, if it does make a noticeable difference, your engine, or the engine’s electronic controlsystems, may need repair. (NOTE: Infiniti recommends Premium for M45)• High octane gasoline has been refined more – it is just a better product.Additional refining steps are used to increase the octane; however, these additional steps do not necessarily make the gasoline a “better” product for all engines. The additional additives might, however.
