srwong wrote:
ok cool. i'm gonna have to get some time to do this. now, ESP said to get 1-1/2 or 2 times as many lights as you would for normal LEDs with the UV/blacklight. now would this still be true if I get a 9.5 inch flexibile LED strip from Oznium?
ok if ur gonna do this the best way is to do what i did.......Put one set under the dash "by ur feet" and the other one under the bar that pushes the seat back.
as to the part with the wiring im not sure on that but i wouldnt do that bc its gonna be annoying to have a set hooked up like that. Meaning ude have wires sticking out bc i doubt u can hide them perfectly "not doubting u just doubting space". If you want to add leds to like ur doors or under the doors and wire em to the "open door turn on part" itd be better than doing the whole footwels like that. And you want the leds to last best way is to not have them on all the time i would just throw a switch to em bc "technically" if u have it set up like this it could be looked at as illegal if u get a d!ck cop "or by me it would be",,,,,,we cant have any footwell or underglow on while driving. Just do a switch and u can turn em on every time u get in if u want.
Oh there is a contraption that does "split" the wires so u could run it to the doors too ive seen it b4 so IT CAN BE DONE BUT i would just stick to a switch bc i wouldnt know where to wire it w/out seeing it
