Jacko3 »
https://forums.nicoclub.com/jacko3-u85814.html
Tue Dec 09, 2008 7:58 am
Nate:
I am not too concerned about number 1 of your post especially with minimal set up like an air intake and catback exhaust. With test pipes, it could be a different story as the timing could even lean out the car even further as my current set up is already doing. However, I wonder if the 93 octane I use is sufficient enough to handle the additional timing advance compared to say, if I used, 91 Octane gas since I am in a lower elevation int he southeast? If i could find a gas staion with a higher octane rating, i wouldn't be worried one bit about this.
However, the ECU is likely to re-adjust the timing as it learns along, and on the fly. The self-learning ECU is that good. And so, I would be worried more about number 2, especially if a person paid some money to get the timing adjusted.
Before I make any adjustment to my timing this coming weekend, i will first ask them to tell me what degree the computer is showing. If, its 14* then I might take it up to 16*. If its at 15*, I may then take it up to 16*. if its at 16* then I will leave it alone.
