driftin8nez wrote:Ok i have decided to do the Q brakes for many reason including the fact i can still use my alloy 92 LE wheels. Anyway here is my question. I want to get axxis pads when i do the convertion so should i get the metal masters or the ultimate pads? The metal master seems better suited for performance dailly driving where as the ultimate pads seems to be more track oriented. But maybe i have no idea what im talking about. Also has anyone ever measured stopping distances before and after a q brake upgrade? Here is the parts list im going with.
front Q brake calipers-junkyardfront brembo OE rotors Q- Group buy centerfront Axxis pads Q - GBCRear Brembo OE rotors 240 - GBCRear axxis Pads 240- GBCFront and Rear SS lines - PDM or eBay
Should run me somewhere is the $350- $400 range
You can get your brake lines from us (
http://www.splparts.com) we are a NICO sponsor and our brake lines are $88 shipped within the US. They also are covered to prevent premature wearing of the stainless steel weave and teflon liner. We have them in stock, and if you were to order them off of our website you need to order the BANJO fitting lines for the front and rear.
Some other suggestions would be, one change out your brake fluid. Old hydrascopic brake fluid (Dot 3 & 4 & 5.1) fluid absorbs water from the atmosphere naturally. Water has the effect of lowering the brake fluid's boiling temperatures. This can actually cause a more dangerous form of brake fade because the fluid isn't quickly cooled like the external rotor and pad materials. Cost wise, we carry the ATE Superblue Racing fluid for $16 a can shipped. While you can bleed the system on one can, we suggest 2 cans so that you have extra on hand for when you attend track, autox, or drifting events. We also suggest you change out the brake fluid every year. Also note that ATE Superblue is less hydrascopic in nature than most off the shelf brake fluids.
Another thing we carry that simplifies and vastly speeds up the whole bleeding procedure is Speedbleeders. They have a one way check valve that allows you to just open them and bleed the brakes without constantly opening and closing the valve, so you can bleed the system alot faster and by yourself! Many people think they don't need these, but every person we've ever heard back from after they bought a set loved them. It makes a 2 person 30 minute job into a 1 person 15 minute job. You will need to buy 2 sets of the 10mm Speedbleeders to replace them in all the calipers, they are $14 a set.
If you'd like to order the brake lines, speedbleeders, or the fluid feel free to order off our website (
http://www.splparts.com) using paypal, or contact us with the info below:
Phone: 1-866-SPL-PARTEmail:
[email protected]
