You can get one piece steel shafts from the Driveshaft Shop, you can just go on their site and pick out the shaft you need, year, ABS, MT/AT, ect.bamracing wrote:I was thinking that the one piece steel unit would be the way to go, but I was wondering if there were any advantages for the two piece in my aplication - oval dirt track. Is this going to have to be a custom piece though?
Are you using all of the above? At the moment I have light flywheel and no fan. I was thinking about an Al shaft but thought that and pulleys is too much.uvamosk wrote:Well, To save you the burn.1pcs drive shaft removes the carrier bearing and also reduces the mass of the drive shaft.
With the bearing gone you will be able to feel the diff a little more than usual and with the lighter weight the engine will rev more freely.
I have a 1pcs ALUM and I wouldn't trade it for the world. Its so light and easy to put in and take out.
If you couple a 1pcs light weight drive shaft with a lightweight flywheel and all light weight pullies and take the fan off the engine You will have a much more responsive engine. Due to the reduction in resipeating (Way wrong I know) mass.
Not really, thats just about it. If you want to help your carrier last longer, I would think about building a little scatter shield for it, so it doesn't get packed with gravel.bamracing wrote:$300 plus for a one piece steel driveshaft is way too much to put into a car that can be claimed for $600 at the end of the race. Do I have other options besides $300 for a one piece or the two piece stock unit?
