miamiheat3332 wrote:Are you sure they are installed correctly? Did you get the right ones?
When i put mine on, it was noticeable immediately. The rear maybe a little less, but thats cause my rear was sagging already.
Well I had changed to kyb struts about a year ago and the struts lowered it a little bit, maybe that is why it isnt so noticeable? :/
By the way, I changed the links also and removed running boards to get extra weight off
I am pretty sure they were installed correctly and they are the ones from 4x4parts. Hopefully by the end of the week the drop would be noticeable...
