miamiheat3332 »
https://forums.nicoclub.com/miamiheat3332-u103568.html
Thu Jan 07, 2010 4:19 pm
I assume its probably settled more by now and recently i was parked by a stock height pathfinder, and i truely do have about 2 inches lower from the fender to the wheel.
And the height from the ground to the frame parts underneath will be higher now because i have those pirelli snow and ice tires on, right when i put them on it gave me like a close to 1inch lift. but you can still definatly see its lowered if you know your pathfinders.
also i will add, you will feel the bumps in the road more and that kind of stuff, its more severe on a lowered SUV than a lowered sedan.
As long as roads are good, minimal bumps, then you will enjoy it, if the roads are really s***ty, depends how loaded the car is, since i noticed when i have 5 people, the return from bumps in the road is much more stonger. All in all, i smoke many people on exits and windy highways in this thing now, theres almost no body roll either, and i have sticky snow and ice tires so yeah, we will see when i get 20;s later in the spring, its gonna handle even better cause alot lot less tire sidewall to flex on the turn,
i will post some pictures up sooner or later on how its stance is at the moment.
Modified by miamiheat3332 at 9:25 PM 1/7/2010
